Grinding going into 5th gear?
I am noticing that when the engine is cold, shifting in the 5th at about 65-70 mph it will make this quick nasty grinding noise. If I shift very slowly and gentle it won't do it. Once the oil temp reaches 200F it's not an issue.
What do you think it is? Shifter cable adjustment, need new gear fluid (68k on odo) or..?
Before filling up, let us know if the level was low to begin with. I am still unfamiliar with the 997 tranny, but on the 915 tranny, the higher gears tend to get lower lubrication if low or when the car isn't used enough.
I did change the manual trans fluid- no improvement at all..
However, my shifter cable broke and I replaced it with new cables (there are two). It shifts amazingly smooth now! But the 5th still grinds when shifting fast.. Oh well.
SlinginHoss
06-19-2023 12:48 PM
