Aftermarket Bluetooth for '06 997 C2S
Old 01-21-2013 | 05:30 PM
kiddoutlaw's Avatar
kiddoutlaw is infamous around these parts
Originally Posted by johnnyb2016
I took a little longer to install my Dension as I wanted it inside the car and not beside the CD changer.
It's not difficult at all, connect it into the MOST network, +12v and earth.
I fitted the unit just in front of the gearshift and ran the Ipod and other cables to the storage box at the rear of the centre console.
The microphone is in the same position as the factory one, have had no issues with sound at all.
Johnny - How did you run the power source? Mine was run through the amp so now i can't use the radio with out the ignition in run. Says AMP error.
  #32
Old 01-21-2013 | 08:45 PM
Terry Fortune's Avatar
Terry Fortune has a spectacular aura aboutTerry Fortune has a spectacular aura about
Awesome thanks guys
  #33
Old 01-22-2013 | 11:15 AM
johnnyb2016's Avatar
johnnyb2016 is infamous around these parts
As it was inside the car I took it from the cigar lighter socket in the footwell. It's permanent live, just put an inline fuse in it.
  #34
Old 01-30-2013 | 06:35 PM
DelReyCustoms's Avatar
DelReyCustoms has much to be proud ofDelReyCustoms has much to be proud ofDelReyCustoms has much to be proud ofDelReyCustoms has much to be proud ofDelReyCustoms has much to be proud ofDelReyCustoms has much to be proud ofDelReyCustoms has much to be proud ofDelReyCustoms has much to be proud ofDelReyCustoms has much to be proud ofDelReyCustoms has much to be proud of
here a great option if your tired of the tookie or Media bridge here a great option. to get rid of the factory PCM... also iPhone 5 and Samsung Galaxy III metadata compatiable.
  #35
Old 01-30-2013 | 06:36 PM
you know you can fin ACC 12v switched in the passanger fuse box. there is an empty fuse slot that when the key is turned on it it put out 12V 7.5Amp
terminal_ac
09-12-2015 03:26 PM
pilotscottb
09-01-2015 10:29 PM
bhart192
08-29-2015 06:20 AM
Quick Reply: Aftermarket Bluetooth for '06 997 C2S
