Accelerating on snow - rear to the right?
Hi! I have a 2007 C2 and have just moved to Michigan.
Love the car on snow - with winter tires!
Today, though, I did notice that if I try to accelerate hard on snow/ice, the rear always seem to want to slip to the right.
Is this normal?
Why not the left?
A problem??
I'd appreciate any advise...
Is this normal?
Why not the left?
A problem??
Is this normal?
Why not the left?
A problem??
Is this normal?
Why not the left?
A problem??
How this applies to you. All things being equal (ground, road angle, etc), due to the rotation of your driveshaft, the right (passenger) side of the axle lifts slightly under harder acceleration releasing traction to that side. Like I said, a standard differential will always send power to the wheel with the least rolling resistance, in your case the right wheel, causing it to spin more, causing you to lose more traction on that side and move accordingly.
This being said, limited slip differentials are "limited slip" for a reason. While they work to automatically reduce the spin on a wheel that has lost traction and revert additional power to the wheel with more traction, reducing slip, you still "slip".
Here's an example of a pro stock drag racer that still moves laterally under extremely hard acceleration.
It's the second car shown at 20 seconds.
All in all, it's totally normal. lol!
cnebrask
10-03-2024 08:19 PM
turbotuner20v
09-11-2015 12:02 PM
Fabspeed Motorsport
Audi
08-21-2015 11:30 AM
