whats the best size of spacers for 997.2 S narrow body?
Old 02-04-2013 | 05:10 PM
luckyc27's Avatar
luckyc27 is infamous around these parts
hi guys,
It's been a little bit more than 1 month I've been driving my 997 and I'm now considering to add some spacers to the wheels to make the tires look wider I guess.
I have a 09 997.2S narrow body, stock 19" wheels and I wanted to ask you guys what's a good size of spacers to get for the front and back and what brand to get too?
Thank you
Old 02-04-2013 | 05:13 PM
luckyc27's Avatar
will 7mm front, 15mm rear be the perfect size??
Old 02-04-2013 | 05:51 PM
Bullseye7's Avatar
Bullseye7 is infamous around these parts
Many say 7mm front and 15mm rear is the perfect way to go. I know that's what I'm going to do on my 06 997.1 C2S with oem 19" wheels. From what I understand, with those wheels, you can go 15mm all around if you want as well.
Just make sure you get the right bolts to go along with the spacers.
Old 02-04-2013 | 06:21 PM
Carnut12's Avatar
Carnut12 is infamous around these parts
My car came with 5mm and I think the wheels look perfect. 7mm is not far off, but I could not imagine going 15mm.
Old 02-04-2013 | 06:38 PM
NorthVan's Avatar
Here is the spacer thread that shows what 7mm and 15mm look like versus stock
https://www.6speedonline.com/forums/...installed.html
Old 02-04-2013 | 06:47 PM
luckyc27's Avatar
NorthVan, thanks for your link, I think I'll do 7mm and 15mm, I have the same color meteor grey and same wheels; however, I wonder why some people say the 15mm spacers are wayyy too much? they don't look that far out from your pics.
Old 02-04-2013 | 07:02 PM
krysFly's Avatar
krysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant future
I concur
Old 02-04-2013 | 07:20 PM
NorthVan's Avatar
The rear wheels/tires sit flush with the edge of the fenders, I am sure you could go 10mm up front without rubbing, although I have never tried it. Since you are in OC, I would talk to RSS, they make them, and are close to where you are.
Make sure you buy the correct length wheel bolts.
Old 02-05-2013 | 04:03 AM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
7mm all over i think is the best!
Old 02-05-2013 | 08:12 AM
phily911's Avatar
phily911 has a spectacular aura aboutphily911 has a spectacular aura aboutphily911 has a spectacular aura about
When I put on my new wheels I am going with 7mm and 15 mm spacers. If you want a flush look in the rear and front that's the way to go...
Old 02-05-2013 | 10:41 AM
jsimon77's Avatar
jsimon77 is infamous around these parts
I purchased my C2S and then changed the wheels to the turbos. I'm also interested in adding spacers but since I changed my wheels to the turbos I'm not sure how that should adjust the way I think about the spacers? Are the turbo's I got the same size as the originals that I had...meaning that doing 7mm and 15mm will be fine?
Old 02-05-2013 | 10:49 AM
Why 7mm for me? Having the wheels flush with the body work will exeggerate the space between the fenders and the wheels. Now if your setup is stock which means not lowered that spacer in the rear will show the space. You wont like it and next thing you will want to do is lower the car. With 7mm spacer, that space between vodywork and wheels is still hidden.
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
08-21-2015 06:34 AM
ModBargains
08-20-2015 12:28 PM
PelicanParts.com
08-18-2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 03:42 PM
Quick Reply: whats the best size of spacers for 997.2 S narrow body?
