Softronic ECU chip - Battery Charger
Old 02-07-2013 | 04:55 PM
Tigerbite84's Avatar
Tigerbite84 is infamous around these parts
Do you guys actually have to hook up the battery to the charger while uploading the new ECU map?
Old 02-07-2013 | 05:12 PM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
I hooked mine up to the trickle charger to be safe. Probably didn't need to. After all was said and done, the download took about 1-2 minutes.
Old 02-07-2013 | 06:04 PM
MYC2SPC's Avatar
MYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really nice
Do exactly what "Vivid Racing" states for "Softronic Flash" and you will not have any problem period!
Old 02-07-2013 | 06:13 PM
NorthVan's Avatar
I didn't connect it to the battery, and even had my computer crash when down loading the new file.
I reinstalled the original file, and then re started the install of the softronic and it was all good.
Old 02-07-2013 | 06:22 PM
MYC2SPC's Avatar
And if it hadn't gone successfully? I just like following directions so if there is a problem, I have my bases covered.Sounds right to me!
Old 02-07-2013 | 07:35 PM
RaidersR1's Avatar
RaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of lightRaidersR1 is a glorious beacon of light
I didn't hook mine up and it went just fine. Did have the laptop on charger though.
Old 02-07-2013 | 08:22 PM
NorthVan's Avatar
Then you get it fixed.
If you don't think your battery can handle the 15 minutes , it is time for a new one.
Old 02-07-2013 | 08:38 PM
MYC2SPC's Avatar
I love ones like yourself on forums that I frequent that know it all!
Old 02-07-2013 | 09:01 PM
NorthVan's Avatar
It is better then not knowing anything
Old 02-08-2013 | 09:23 AM
jjc4scab's Avatar
jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !
This is an interesting thread.........
I see we have someone with a paper a$$hole!
Old 02-08-2013 | 12:13 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
It appears there are many ways of doing it. No need to follow the directions. If your planning to do it let us know what method you used and how it turned out.
Old 02-08-2013 | 05:45 PM
buck986's Avatar
buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !buck986 Is a GOD !
I did..thru the cigarette lighter...got the set up on Amazon and use it during the winter to keep batteries charged.
Old 02-08-2013 | 08:05 PM
MYC2SPC's Avatar
Yep.... you answer your own response.
Old 02-08-2013 | 08:13 PM
MYC2SPC's Avatar
Amazing with the moderators on this forum!You can't even contact these individuals!I love the bias opinions here with no moderator influence until???!Bad,bad,influence!
Old 02-08-2013 | 08:30 PM
NorthVan's Avatar
The only that seems to have issues here is you GOLENJEEPTJ! Everyone has an opinion, and if you don't agree, you turn into a troll!
No one likes a troll, and by the the negative reputation you have, it should be pretty clear that people have told you this in the past.
If you just chill out perhaps you might make some friends.
Quick Reply: Softronic ECU chip - Battery Charger
