seriously in need of an expert
Old 02-14-2013 | 08:37 PM
Domer911's Avatar
Domer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond repute
MY2010 997.2 4S, I have removed nearly every fuse and cannot find the one connected to the footwell lights and/or the glove box light.
Any ideas?
The fuse chart does not indicate specifically a fuse for any of the interior lights. I'm a bit lost, and I think I've got zero power to the glove box light, but all the rest of the lights are working.
argh!
Old 02-14-2013 | 08:48 PM
gasongasoff's Avatar
gasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond reputegasongasoff has a reputation beyond repute
Did you check the microswitch on the back of the glovebox? I had the same problem (thought it was a fuse), but that's what it turned out to be.
Old 02-15-2013 | 05:22 AM
Rotes's Avatar
Rotes is a splendid one to beholdRotes is a splendid one to beholdRotes is a splendid one to beholdRotes is a splendid one to beholdRotes is a splendid one to beholdRotes is a splendid one to beholdRotes is a splendid one to behold
you're in luck, this board is FULL of experts
Old 02-15-2013 | 07:09 AM
krysFly's Avatar
krysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant futurekrysFly has a brilliant future
Lightbulb?
Old 02-15-2013 | 10:01 AM
Domer911's Avatar
Originally Posted by krysFly
Lightbulb?
It's not the bulb.
Old 02-15-2013 | 10:26 AM
yvesvidal's Avatar
yvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of light
I would try to measure the voltage BEFORE the switch, if possible.
Yves
Old 02-15-2013 | 12:42 PM
Domer911's Avatar
Yves
zero voltage
Old 02-15-2013 | 12:44 PM
Domer911's Avatar
PM sent
Old 02-15-2013 | 01:20 PM
yvesvidal's Avatar
Originally Posted by Domer911
zero voltage
So, you have zero volt between any pin of the switch and the ground? Then, the 12Volts is not coming to the switch....unless the switch is fed by the ground. I would have to check the wiring diagram to figure it out.
How about the voltage between each of the Bulb contact and the ground?
Yves
Old 02-15-2013 | 02:58 PM
Domer911's Avatar
Yves
this may give you some indication of my level of understanding...
I stick the meter in both holes of the harness that attaches to the bulb housing, and I get nothing. I cannot speak to "ground" because I am completely ignorant. Is this hopeless without a service tech?
Old 02-15-2013 | 03:09 PM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
Near the fuses, on the fuse box, up and right corner, there is a red thing that will pop out if you short any of those contacts. Just push it back in and you will regain power.
btw, I'm not an expert...
Old 02-15-2013 | 03:14 PM
yvesvidal's Avatar
Let me be more precise. The negative lead of your multimeter (black lead) must be connected to a big metallic bolt or something that touches the chassis of the car. Then with the other wire of your multimeter, you can measure different points. This way of doing is giving you an absolute voltage. For instance one of the wire of the switch (connected to your red multimeter wire) should read 12Volts. Similarly, one of the contacts going to the bulb should read 12Volts when the glove box is open.
Nothing more complicated than that.
Yves
Old 02-15-2013 | 04:13 PM
Domer911's Avatar
Thank you. If it turns out to be that easy in this case, dinner is on me.
Old 02-15-2013 | 05:25 PM
Taxi!'s Avatar
Taxi! is just really niceTaxi! is just really niceTaxi! is just really niceTaxi! is just really nice
Wait, you're "seriously in need of an expert" because your glove box light doesn't work?
Old 02-15-2013 | 05:45 PM
Domer911's Avatar
Yves
Okay, now I have done this. I get a reading of 12.19 volts at one of the metal conductors once it is plugged in to the wire harness. I cannot get a bulb to light, however. I feel like I am on Candid Camera. Coupled with the fact that I'm a technical ritard, this simple little BS issue is going to be my UNDOING.
By the way, the red thing in the upper right of the fuse box was out enough that I pushed it in a considerable distance, as if to reset it.
Either way, I seem to get voltage to the socket, and I have a handful of bulbs that I pulled from interior lights that were working, and I cannot get one of them lit.
I. Am. An. Idiot.
