Please Help! Where does this small Hose attache to ?
6 Speeders can someone please tell me where does this small hose plug into? I have a 2009 Carrera. Here is a picture of the small hose. I was trying to change my cabin air filter and noticed this un attached hose and can't figured out where does it attached to!!!
Joel I guess the nipple that was attached to the battery fell off and I can't fit hose without the small piece. Is it necessary for the vent hose to be attached to the battery?
Cab83... is correct when he says find one and attach it. Primary reason for the vent hose is to vent the gas that leaks from the battery which can be highly explosive under certain conditions. If battery does not have a vent hole you need to get a properly vented battery. Would suggest you go to an Auto Zone or comparable retailer and see if they can get you the proper pastic connecting elbow if the battery has the proper vent hole.
I would look for a hoe with a nipple but that is just me.
NC 996TT
03-23-2023 06:19 AM
