Track tire pressure for Michelin SS
Will be using Michelin SS for he first time to the track next weekend. (First track day for he tires, not for me ;-)
Looking for some advise where the sweet spot is in tire pressure on the track.
Do you mean the pilot super sports? If so, I started out at 32/36 and should have released some pressure as the day wore on. I found that as the surface warmed up and the pressures got up around 44 on the rear that the started to get a little greasy. That being said, I'm a super novice and had other things to concentrate on so hopefully someone else can validate that.
Do a search and see what you find. I know there was a very extensive post from someone who tested the SS's for 2 days and came up with his thoughts on the perfect pressure. I remember thinking his reasoning seemed very sound.
i did a couple of DE's with my old 997.2 3.6 on the MSS. What i had noticed is that anything of 40psi hot, the car would slide more... So i used to start the session as low as 32psi. i was running the factory 18s, size 235/265...
Same results when autocrossing... Anything over 40 the tires slide more... To me the sweet spot is 38-40 hot...
Now with my 997.2 4S, running again on the MSS, i notice the same thing when autox. Anything over 40 the car slides more... Based on that, i am assuming it will be the same at DE events. Now again i am running the factory 19s 235/305...
What I learned this weekend on the track (Laguna - Seca):
The sweet spot for me seemed to be between 34 and 36 PSI (hot).
As soon as the tires reached 38 PSI I noticed that the tires started to slide more.
And that poses the following question:
The tires gained between 6 to 8 PSI from cold to hot. So if I am aiming for 36 PSI, I would have to start with a pressure below 30 PSI. What's the lowest "safe" pressure where I don't run the risk of damaging the tires?
Did the pressures increase with subsequent runs or did you reach those numbers in the first cycle? At thunder hill I noticed the tires getting slightly higher readings with each session but that could have been me pushing the car more as the day went on.
Depending on track conditions, ambient temperature the PSS in my experience I run cold 29/32 on my GT3; 34/37 on my C4S. I find that I try to keep the rears around 36 hot Rears; 34 Fronts; above 40 they get that greasy feeling. Have been on the track when it is raining and ambient temperature in the 40s -50s and they hardly bump up in psi. And I second that to add some air via a portable compressor for the ride home.
Depending on track conditions, ambient temperature the PSS in my experience I run cold 29/32 on my GT3; I find that I try to keep the rears around 36 hot Rears; 34 Fronts; above 40 they get that greasy feeling. Have been on the track when it is raining and ambient temperature in the 40s -50s and they hardly bump up in psi. And I second that to add some air via a portable compressor for the ride home.
Any idea what's the lowest pressure you can safely start on on cold tires?
