Faults in Gas Vapor Recovery System
Hi Everyone:
I'm new here. I'm posting this for a local repairman who got stock on the Vapor Recovery System...
The car is a 2007 997 Carrera 4S with 60K KM on it.
The PIWIS faults are : P0456 "Evaporative emission system leak detected (very small leak) and P0455 "Evaporative emission system leak detected (large leak).
The mechanic has replaced the 1. gas vapor recovery tank, 2. the solenoid (I guess a valve on the engine's intake end)(he later told me he replaced the DMTL module), 3. gas cap, 4. the connecting hoses checked for leak. None of these steps corrected the faults. The only thing he has not replaced is the gas tank itself. The faults were reset but would re-appear after couple of days driving.
He's clueless as to what else can go wrong. Help from anyone?
Thanks!
CW
Thanks!
CW
check these links, they may be helpful to ur mechanic
http://www.obd-codes.com/p0456
http://www.obd-codes.com/p0455
This is great help. Thank you very much. The EVAP system isn't hard to understand.
Can anyone help me locate a diagram showing how the EVAP system is connected? An exploded chart or any diagram showing all the parts will be great!
Thanks!!
Thanks!!
10-06-2015 03:43 PM
