Intake valve carbon build-up
Old 09-18-2013 | 04:36 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
Originally Posted by Alan C.
I guess you could look at it as a colonoscopy for your engine. Thankfully you don't have to purge your engine prior to the procedure.
Would be more like an endoscopy, no?
  #32
Old 09-19-2013 | 02:34 AM
808c2s's Avatar
808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !
More like laparoscopy, yes?
  #33
Old 09-19-2013 | 04:42 AM
Fahrer's Avatar
Fahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to all
Originally Posted by L_Perm
Anyone seen this picture? It appears to show the DI occurring at an angle inside the combustion chamber that would also coat the open intake valve with fuel. The upper neck of the intake valve would still be suspect, depending on how good Porsche is at removing oil vapor, etc. from the PCV return. If they've managed a good job at creating a "clean" PCV system, and the DI is actually spraying the intake valve to some extent, then their solution might just be pretty good.
If that picture is accurate why would they even use DFI? With valve open, wouldn't it make sense to use port injection?
  #34
Old 09-19-2013 | 10:13 AM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
Just need a longer hose!
  #35
Old 09-19-2013 | 12:43 PM
Happy911S's Avatar
Happy911S is infamous around these parts
The assumption by some is that if other designs of DI engines have issues then Porsche has to also. Is it possible that the Boxter design engine (horizontal) prevents this issue?
  #36
Old 09-19-2013 | 03:14 PM
Tcc1999's Avatar
Tcc1999 is a splendid one to beholdTcc1999 is a splendid one to beholdTcc1999 is a splendid one to beholdTcc1999 is a splendid one to beholdTcc1999 is a splendid one to beholdTcc1999 is a splendid one to behold
Do you know what if anything they changed to address the problem?
It's been a while and they were exceptionally vague about what they did. I think the CEL was going off due to a misfire. They addressed that (may have changed coils/plugs or something obvious, like I said, I don't really remember and the service records are archived). The car ran fine for about a week and the CEL went off again (misfire). This time they kept it for a week and tried something else; drained the fuel tank and did a few more tweaks. Get the car back and about two weeks later the CEL goes off again. Back to Audi and it's in the shop for another week, this time waiting for the area rep to look at it. They accuse us of using cheap gas but I have every VISA receipt for the past ten years (correlated with the appropriate charge on a spreadsheet) and dug out all the gas purchases for the car (premium but the 91 crap we get in CA). Got the car back, and this time they didn't really say what they did - adjusted this and that, etc. Three weeks later, CEL again. This time it's in the shop for two weeks and they expose the valves and find a pretty significant carbon buildup. They called the area rep, clean off the build-up and give us back the car. Soon thereafter the CEL comes on again and this time we initiated the lawsuit. I remember reading the deposition of the area rep (or some Audi official familiar with the issue) and it was particularly vague and he talked around any specifics of what was causing the problem. Interestingly, it was soon after that deposition that they settled. At no time, other the CEL being on did the car run rough or have any problems.
After we settled the CEL would go on and off intermittently and during a service it was reported that there was throwing misfire codes. It is probably still misfiring but the CEL doesn't go off anymore (it was on and off so much the bulb probably blew out!). It's a third car for errands/hauling now and seldom ever gets driven more than 40 miles at a time so, considering the
what we paid for it after the settlement, it fits that role pretty well.
  #37
Old 09-19-2013 | 05:18 PM
Fahrer's Avatar
No....
  #38
Old 09-19-2013 | 07:04 PM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
the dfi engine on our cars do not have a problem. Porsche knew the problem from previous issues by the other manufacturers. they incorporated a design where the first spritz of the fuel hits the open intake valve and then the main spritz for the power. no worries for dfi owners. same basic architecture still used in the new cars. after almost 4 years no real documented evidence. all i know is as my car ages if feel it actually gaining strenght!! everything to be flowing more freely. and recently with an air filter change i hear her growl some more.
04-28-2022 01:38 AM
The_Ruski_Driver
10-25-2015 09:40 PM
turbotuner20v
09-11-2015 01:02 PM
orbelo
08-30-2015 01:26 PM
