Dead battery mystery
Old 09-22-2013, 02:27 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
I'm all confused.
I just went thru this load testing phase 2 weeks ago. Your load test pic shows less than 12v. Load test should be over 12V. At the rate your pic shows (i.e., <12V, your battery will never be charged by the alternator). What voltage do you get from the alternator (with and without load)? BTW, my alternator showed 13.9v without load (passing), and but showed 12.25 with load (failed).
I am not sure what instrument you are using, but I used a Fluke and my charger (Schumacher) has an alternator-test-mode feature (readings from both units were very very close).
Old 09-23-2013, 03:12 PM
cab83_750's Avatar
Without pretending to be an expert, I just want to clarify thàt based on the info here, you may need to do another alternator test (both load and no load tests). Again without further info, I get the impression that you may have alternator issue.... And perhaps battery issue.
Old 09-23-2013, 04:38 PM
Robocop305's Avatar
Robocop305 is just really niceRobocop305 is just really niceRobocop305 is just really niceRobocop305 is just really nice
I would have the battery and charging system check by a digital analyzer. Take the car to an Auto Zone or Discount Auto Parts.
adnanm3
10-25-2016 08:38 AM
airbusdrvr
12-27-2015 07:43 PM
007 Vantage
10-08-2015 08:35 PM
ek1
Bentley
09-26-2015 11:54 PM
Quick Reply: Dead battery mystery
