Engine Sound
Old 09-24-2013 | 09:15 AM
jabed92694's Avatar
jabed92694 is infamous around these parts
Engine Sound
Hi,
I noticed lately that upon cold start my engine sounds almost like a Diesel engine. Doesn't sound like it used to. I changed the gas to fresh gas and it is still the same. Anyone experience this?
Any ideas what it might be? Seems to go away after time.
Thanks,
Jon
Old 09-24-2013 | 09:23 AM
mattyf's Avatar
mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !mattyf Is a GOD !
That's not a lot of info to go on, but first guess: Look up stuck lifter or collapsed lifter. It can happen infrequently but not be every time you start your car.
Edit, when was your last oil change?
Old 09-24-2013 | 09:24 AM
jabed92694's Avatar
Last oil change was 7k miles. Will be scheduling an oil change very soon.
Old 09-24-2013 | 11:32 AM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
7k miles... Where is it now? 14k 30k 50k, not enough info on that answer buddy.
Old 09-24-2013 | 02:35 PM
jabed92694's Avatar
48k miles now
Old 09-24-2013 | 03:36 PM
eldertec's Avatar
eldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to behold
Changed 7k miles ago,...or changed when the car had 7k miles?
Old 09-24-2013 | 04:13 PM
jabed92694's Avatar
Changed 7k miles ago. Car has 48k mikes now so changed at 41k.
Old 09-24-2013 | 04:29 PM
eldertec's Avatar
2011 4S,...DFI engine...in for an oil change at an Indy Porsche shop,...owner said when he heard it start up he thought something was wrong...loud... Another mechanic said that's how the new DFI engines sound....first one he had heard.
Old 09-24-2013 | 06:10 PM
jabed92694's Avatar
Mine is an 07 4S
Old 09-24-2013 | 06:23 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
I do know how diesels sound, but is your car sputtering? Is it grinding? Hesitating? Sounding as if running on 5 or 4 cylinders.
All I could tell is that your issue occcurs in the morning. Long dark shot recommendation: put some Techron (twice if possible) and start from there.
Old 09-24-2013 | 08:10 PM
mattyf's Avatar
Depending on your driving habits 7k is getting towards the longer end of oil changes. If you do lots of short drives, the engine does not heat up fully and you can get moisture from combustion diluting the oil. Also if you do lots of hard driving or track days you'll want to change it sooner.
It's difficult to diagnose a car from the internet with such a vague description. Did you check the threads on collapsed lifters? Did any of those threads describe your issue? Also, do you let your car sit for long times between drives?
Barring any genius internet arm chair mechanic help, I'd take the car to a competent indy for the oil change and hopefully you can also leave the car there overnight show them the noise on cold start.
Edit, one other thing... could be something in the exhaust that is loose and when it heats up expands and stops rattling.
Here's a thread from the other forum: http://forums.rennlist.com/rennforum...-thus-far.html
and another one with video: http://forums.rennlist.com/rennforum...his-sound.html
Old 09-24-2013 | 10:20 PM
jabed92694's Avatar
It's not really a rattling or ticking noise. The best I can describe it is it sounds like a typical Diesel engine which has a very distinctive sound.
Old 09-24-2013 | 10:30 PM
MYC2SPC's Avatar
MYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really nice
So your hearing a knocking noise?Does the knock speed up with engine rpms?Is it only when cold or after it heats up also?Elaborate?
Old 09-24-2013 | 11:43 PM
jabed92694's Avatar
No not a knocking sound either. It's like a deep grinding noise like a Diesel engine or maybe a truck sounding engine. It's more the tone of the engine rather than a knocking, ticking or rattling sounds. It speeds up with rpm and actually doesn't go away when it heats up. It sounds like I have a Diesel engine now, not gasoline.
Old 09-25-2013 | 03:02 PM
eldertec's Avatar
I would call AAA and have them take my ride to my local Porsche shop,...if you have AAA. Have a pro look at it.
Quick Reply: Engine Sound
