Coolant Level
Coolant Level
With the engine cold on my '05 Carrera S, the coolant level in the reservoir is about 1/2 inch below the minimum mark. I don't think this is critical right now, but I would like to add a little coolant to get it back to at least the minimum mark. My Porsche has been well maintained and I don't suspect there are any coolant leaks. Is this simply a matter of adding a small quantity of recommended Porsche coolant?
look in your owners manual and you'll be astounded as to total coolant capacity (coolant + water at 50/50 mix) of modern Porsches. As such, adding a quart or two of distilled water (yes as stated above must be distilled) will nary change the mix ratio.
Good luck
fill it and make a note of the level and I d make sure it s stone cold...and dead level. drove me crazy when I first got mine until I realized how these two variables are so sensitive to the level.
