Chassis flex? any chassis bar or product to reduce flex?
My 997.2 C4S has quite a bit of flex and makes noise whenever i go up a bump or go up/down a drive way, i can hear clearly the cabin is making noise and the chassis is twisting. compared to my GT3, it doesn't make a sound at all. is it because my GT3 has roll bar?
is there any type of bar or product that will reduce the flexing in non-caged 997? i don't want to put a cage in my C4S as it's my daily driver and will look weird.
http://sharkwerks.com/porsche/techni...s-ztadpol.html
At least the dog bones and toe-bump steer in the rear.
these suspension links are for the subframe / handling, but won't necessarily strengthen the chassis? i just want to make the chassis stronger and not hear those squeaking sound whenever i go over bumps
a lot of JDM cars have like floor bars, under brace, x-brace....etc. does anyone make these for porsche?
For a chassis as stiff as these, I wouldn't want to add more weight trying to improve on it. As noted above, it amazes me each time I jack up one front jacking point and get 3 wheels off the ground. And that is with my cab!
Exactly... it's funny watching all of us lowered 911s pull out of steep driveways sideways on 3 wheels
Can anybody explain why does it creak when going diagonally if its really that stiff. The twisting is causing some body flex causing the squeaking noise of the rubbers for the doors and sunroof if so equiped.. I think our brothers are mixing up stiffness with the short wheel base. I think the 3 wheels off is caused more by the short wheelbase of our cars.
actually i am hearing the sunroof squeak and the door weather stripping. why do i know? well firstly, i hear it coming fromt here and second when i lube these rubber pieces the squeaks disappear. dealer also acknowledges the squeaks come from there. only thing is it happens only when car goes diagonal over humps and bumps
All car chassis' flex to some extent. 997s are *exceptionally rigid*. The squeaks you are hearing has more to do with how the interior panels are fitted than with chassis flex (which is unavoidable).
FYI, die-hard Porsche racers prefer a sunroof-deleted-optioned car. Or, they get them welded.
Thoughts?
Thanks!
Steve
PS: I never had this happen on my 2007 C2. Was something changed? Or did I get a lemon?
Is this standard practice at Porsche dealers to get rid of these noises? I am taking it to them on Saturday for a bunch of work...
