Why does it take longer to measure oil now?..
Old 11-02-2013 | 04:08 PM
slicky rick's Avatar
slicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of lightslicky rick is a glorious beacon of light
Before after a run and the oils is sufficiently warmed up, it only takes around 5 to 6 seconds to check the oil. Now even after a long drive and the oil is warmed properly it takes 40 or more seconds to measure the oil. Is it a sign somethings about to give? The electronic measuring stick perhaps? 997.2 electronic oil measuring system
Old 11-02-2013 | 04:24 PM
PTParks's Avatar
PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !
My thinking is nothing is going wrong. Maybe the system knows how long the engine has been running on the latest cycle and ensures that time is given to allow all the oil to return to it's proper level before measuring. I've had mine take as long as yours before revealing the oil level. However, the old school in me misses being able to pull a dipstick and visually check the oil level and level of color change in the oil.
Old 11-02-2013 | 05:33 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
mine does the same thing... you are fine.
Old 11-02-2013 | 07:22 PM
Just wondering why it was not like that before.... Less than 10 seconds to about 40 secs to a minute is quite a gap. Im now thinking that it could be related to engine servicing because im nearing 10k km on the year on march...i think. Is the oil measuring affected by oil viscosity? New oil shorter inteval, old oil longer interval...
Old 11-02-2013 | 07:50 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
I think I am going to be flamed about this but I thought the best most accurate way to ck oil level is when the engine is cold, like in the morning. After all, it takes some time for all oil to drop into the oil pan.
Old 11-02-2013 | 09:10 PM
DasVWBabe's Avatar
DasVWBabe is infamous around these parts
Should I be concerned if after a 15-20 minute drive it takes ~4 minutes+ to measure my oil? '07 997 Targa4S for reference.
Old 11-02-2013 | 09:17 PM
stevefrommn's Avatar
stevefrommn has a spectacular aura aboutstevefrommn has a spectacular aura aboutstevefrommn has a spectacular aura about
Our cars have five oil pumps. So that means there are 5 sumps of some kind to pump from. They must need time to bleed down or something. I really miss a Dip stick. It not only let you check the oil but you could smell it and actually look at it.
Old 11-02-2013 | 09:29 PM
eldertec's Avatar
eldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to behold
Mine is the same,...sometimes 50+ seconds. Usually less than that though. Love the automatic way to check!! Dipstick is for the birds!!!
Old 11-02-2013 | 10:17 PM
Macster's Avatar
Problem is the oil is cold and its volume is less than it will be once up to the temperature.
If the engine is up to temperature it takes no time for the oil to drain back. There's not much draining to take place anyhow as the camshaft covers have their own scavenge pumps to remove any oil from under the camshaft covers.
I know with my Boxster once up to temperature it takes just a few minutes of time after I shut off the engine that I can check the oil level without waiting more than 5 seconds and the level reading agrees with a reading taken after the hot engine has sat longer after being shut off.
Some engines now one can't check the oil cold. My Turbo for instance has to be hot (170F or thereabouts) for the oil e-level to even allow a reading to be taken.
Old 11-02-2013 | 10:21 PM
cab83_750's Avatar
We should really check our manuals. I am certain that my 07's cannot be checked until after many many minutes of waiting AFTER shutdown.
Old 11-03-2013 | 04:34 AM
too tall's Avatar
too tall is infamous around these parts
5 mins after warmup and 10 mins. cold is what it takes for mine.
Old 11-03-2013 | 05:34 AM
cerbomark's Avatar
Dfi s and pre DFI are different correct... pre 09s still have dipstick ?
I did notice if I didn t like the measurement on the dash that if I waited a few mins and did it again I would get an extra block on the level. At first I was old school wanted a dip stick but now I m used to it.
FYI, If you try to do it when the engine is too cold it will tell you so on the dash.
Old 11-03-2013 | 07:06 AM
jhbrennan's Avatar
Originally Posted by cerbomark
pre 09s still have dipstick?
No dipsticks in 911's for many years - don't know when they stopped - maybe with the 996 or even earlier.
Old 11-03-2013 | 12:38 PM
PTParks's Avatar
Dashboard measurement will not show up unless the motor is at operating temperature.
Old 11-03-2013 | 12:45 PM
cab83_750's Avatar
Unless I'm missing something, Untrue. I check oil 1. In the morning before going to work, 2. Leaving the office (after 10+ hrs of parking).
Quick Reply: Why does it take longer to measure oil now?..
