C4 wheel hop in tight turns - normal?
Old 10-24-2014 | 07:33 AM
malahhaor's Avatar
malahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to beholdmalahhaor is a splendid one to behold
Ladies and gents got a qq for you.
This is my first AWD vehicle so i don’t know too much about it.
I have 06 C4 and noticed that in parking lots when im in tight turns, the front outside wheel hops as if it wants to spin way faster than the car is moving.
Is this normal? Seems like a sure way to destroy a dif.
Old 10-24-2014 | 08:37 AM
yvesvidal's Avatar
yvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of lightyvesvidal is a glorious beacon of light
I have noticed the same on my C4S. I don't think you need to worry about it.
It only happens when you go backward and steer completely to one side.
Yves
Old 10-24-2014 | 08:59 AM
malahhaor's Avatar
i noticed that it does it when im going backwards or forward. So in the morning i back out straight because im next a curb and when i turn almost to lock to the right going forward it will hop.
Going backwards in the evening after work at a different parking lot with tight turn outside hops as well.
But if you’re saying yours is the same so i guess that’s gust how the awd is.
thanks!
Old 10-24-2014 | 11:34 AM
Jpara98's Avatar
Jpara98 is infamous around these parts
2006 C4 owner as well...say thing on mine. I has told that it is normal when turn to lock.
Old 10-24-2014 | 11:37 AM
barncobob's Avatar
barncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the roughbarncobob is a jewel in the rough
mine does same,,,i try not to get into situations where I need to go full turn lock
Old 10-24-2014 | 01:04 PM
yvesvidal's Avatar
Yes, my tires are factory sizes.
The issue was more obvious with the Michelin PS2 but somewhat subdued with the Michelin Pilot Super Sport (all in 19" diameter).
Yves
Old 10-24-2014 | 06:28 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
This has nothing to do with 4wd and is no reason to be sold new tires. All 997's will "push" the front wheels if you crank it too hard from a start or at low speeds. The steering angle under those conditions (it is worse in the cold when traction is less) is too acute (wheel turned too far) causing the tires to slip on the road and the suspension to pogo as the tires skid rather than roll. The "cure" is to familiarize yourself with the steering feel and reduce steering input (counter steer) as you feel the front start to plow on the road. This is one of the few things of which you can say: they all do it".
Old 10-24-2014 | 09:32 PM
malahhaor's Avatar
Interesting, good to know.
Thnaks
Old 10-27-2014 | 06:41 AM
Wheeler's Avatar
Wheeler is infamous around these parts
Yep, what he said. My C2S does it.
Old 10-27-2014 | 04:13 PM
lowbee's Avatar
lowbee is infamous around these parts
I think my C2S does it too but I am not quite sure....does it make any sound when it do that ?
I always wonder if there is something wrong with my steering or some joints or something.....it is most noticeable when I am doing a quick U-turn....
Old 10-27-2014 | 05:34 PM
eldertec's Avatar
eldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to behold
On tight turning...my 2011 C4S did it.
Old 10-27-2014 | 09:09 PM
JustinCase's Avatar
JustinCase is infamous around these parts
C2S: I usually don't notice this in the summer with summer rubber. But it is extremely obvious with summer tires when the temperature drops below 45F to 50F. It also was more noticeable when my front tires were 5 years old -- much better with fresh rubber.
Old 10-28-2014 | 03:58 AM
sneakybear's Avatar
sneakybear is infamous around these parts
Rudolph Ackermann discovered the same thing... worth a google.
Old 10-31-2014 | 05:28 PM
malahhaor's Avatar
Thank you all for the info. Now that its in low 30s and I'm a little more intuned with the car (had it almost a month) I understand and feel exactly what's going on. Its exactly as you guys described it.
P.S.
I know 30s I should not be driving on PS2s but it was almost 70 on Monday
Winters are on order
Old 12-03-2014 | 08:02 AM
Ed_NJ's Avatar
Ed_NJ is infamous around these parts
Wheel Hop
Excellent. Finally a correct answer.
Quick Reply: C4 wheel hop in tight turns - normal?
