Low volume road sound
Old 04-19-2015 | 09:58 PM
kauai_diver's Avatar
kauai_diver is infamous around these parts
Think I need new tires but they are semi-new..
At 40+mph I hear a very low but annoying "woa-woa-woa" sound.
Any ideas for a 9+ year Porsche owner?
Thanks,
Kurt
Old 04-19-2015 | 11:30 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
I get the same noise at higher speeds when my wife is in the car. More like "whoa, whoa" though.
Sorry about that. Imo though you are going to have to better describe what is bothering you and narrow in better on the condition of the tires and if you are hearing road noise or mechanical noise.
Does it happen on all surfaces, get louder w speed, does it go away if you push the clutch in or shift into neutral? Worse at higher rpms or lower rpm's.
As for tires reach under inside rear and feel in the inner tread for the wear bars. If they are contacting the road you will get a rumble. The fronts are easier to visually check.
Could be a hundred things. At least.
Old 04-22-2015 | 02:45 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
tires...
Old 04-22-2015 | 04:15 PM
Burg Boxster's Avatar
Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !Burg Boxster Is a GOD !
Agree - sort of. Could be many things, maybe not hundred but definitely many like tires, bearing, axle, etc. Isolating more as to when, how, conditions, gear, will help. Otherwise have a qualified mechanic inspect. They'll find quickly.
Good luck
Old 04-22-2015 | 06:02 PM
Gpjli's Avatar
Good luck
I stand by my estimate. Actually it could be 124 things if you count each individual wheel bearing
Old 04-23-2015 | 03:16 PM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
When's the last time you had them rotated and balanced? I'd start there. Could also be a wear thing and just need to have them switched around a bit.
-Luccia
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old 04-25-2015 | 08:17 PM
Thanks all for your replies. I'm *hoping* it's just the tires because it's now my daily driver with 85,000+k miles I bought long distance (non-sticky) tires 2 years ago and they should be good for longer than that. I'll get it checkout out.
Armytrix_F1_Exhaust
07-07-2019 11:31 PM
Money2536
09-01-2015 04:56 AM
Quick Reply: Low volume road sound
