997 AUX cable-cant figure out how to switch to AUX mode
Old 06-17-2015 | 09:15 PM
Porsche997.'s Avatar
Porsche997. is infamous around these parts
I just bought a 2007 porsche carrera s. I was looking in the glove box and i found an AUX cable iam guessing its the custom one. I loked at the radio but there is nothing that says AUX i tried everything i couldnt figure out how to switch to AUX mode. Any help!
Thank you
Old 06-17-2015 | 09:19 PM
Wayne Smith's Avatar
Wayne Smith is infamous around these parts
The 997.2 PCM had a Source button that displays available sources to select from.
Old 06-17-2015 | 09:22 PM
Whats 2PCM iam sorry i just bought the car and iam not familiar with porsches
Old 06-17-2015 | 09:31 PM
997.1 was the model built from 2005 through 2008. In 2009 a generational (not model) change was made designated by 997.2. The PCM (Porsche Communication Module ... or Management) was updated as well. I don't know if you have a Source button or not, but that's how mine selects the Aux input.
Old 06-17-2015 | 09:33 PM
BTW ... Welcome aboard. Post some pictures and give some details when you have a chance. You've got a great ride. Read the Owner's Manual to acquaint yourself. Use this Forum as well. Most importantly ... Drive drive drive.
Old 06-17-2015 | 09:36 PM
This is what mine look like!
Old 06-17-2015 | 10:06 PM
I'm not an expert here either. The Audio button would be my first guess. FWIW, my PCM only offers Aux of the Aux input is attached.
The Owner's Manual is pretty good and I'm sure someone here with a 997.1 has the answer as well. Sorry I wasn't much help.
Old 06-18-2015 | 06:36 AM
kcheves's Avatar
kcheves is infamous around these parts
Here's a link to a PCM 2 User Manual. It is not exactly what you have, but the Audio functions will be similar.
http://coochas.com/porsche/Resources/PCM2.pdf
You can also buy the PCM 2.1 manual from Suncoast Porsche:
http://www.suncoastparts.com/product/WKD95032405.html
Bu the manual will only get you so far., as your car did not come with an AUX input. It was either added by Becker (who makes the PCM), or someone has installed a 3rd party interface, like the Dension Gateway 500.
It may be configured to look like a CD Changer to the PCM, so see if selecting CD Changer allows you to access the AUX input.
Old 06-18-2015 | 08:25 AM
StormRune's Avatar
StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !StormRune Is a GOD !
It's not clear what type of connector you have in the glovebox. Is it a 32 pin iPhone/iPod connector or something else? If it is the 32 pin connector, then kcheves probably nailed it. Plug in an iPhone or iPod (you can use a Lightning to 32 pin adapter if necessary) and then you will most likely find your music under the PCM's CD Changer setting. The Dension spoofs the system into thinking an iPhone/iPod is a set of CDs in the changer.
Old 06-23-2015 | 02:19 AM
Tarek307's Avatar
Tarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond repute
YOU HAVE A SWITCH EITHER UNDER THE DASH OR IN THE GLOVE BOX- Its probably a Built in FM transmitter direct connection- It will switch your RADIO off & it will be an AUX when you hit the switch. Look for it under dash, footwell, or sometimes glove box- Thats how most of those are installed
Old 05-16-2020 | 12:15 AM
petrk's Avatar
petrk is infamous around these parts
I had the same problem on my 997.2: I could switch SOURCE between AM/FM/DISC/iPod/USB, but AUX wouldn't show up. Turned out, you can go to DISC > OPTIONS > "SET DISC / AUX" and enable the AUX. Then AUX will start showing up under SOURCE.
I know, it's been 5 years since the questions, but maybe somebody like me will find this information useful
Old 06-04-2020 | 01:54 PM
jwex16's Avatar
jwex16 is infamous around these parts
mine is set up to just use the 0 button on the radio. when you use it , it activates the aux port in my console. Can use music on phone and the phone handsfree. not sure how to answer phone from display yet.
Old 03-29-2022 | 07:42 AM
EQuuS's Avatar
EQuuS is infamous around these parts
Hi there
Did you actually find out how to select the AUX function ??
I have recently bought a 997 C4S Gen 1 and i cannot fathom out how to find AUX on the PCM system ????
Old 04-02-2022 | 11:22 AM
ivanbastos's Avatar
ivanbastos is infamous around these parts
it works for me today (2 years after your answer). Regards.
Old 04-13-2022 | 09:14 AM
ktwiford's Avatar
ktwiford is infamous around these parts
I'm a new owner of a 997.2 2011 Carrera S Cab and I'm very much enjoying it already. I'm also curious about the Aux input issue. I'm sure I can figure out the source issue on the PCM, but the standard aux cable that I have (and that works in my other "older" vehicles with aux inputs) does not seem to fit into my 997.2 aux input. Does this make sense? Is there a slightly different size aux cable I need for the 997.2?
Thanks-Kurt
Quick Reply: 997 AUX cable-cant figure out how to switch to AUX mode
