Water Pump
I know they went with a water pump on mine that had a brass impeller rather than the OEM composite type. I believe is was a Graf water pump.
Yep it's 4 hours labor charge and let's not forget about the two gallons of Porsche coolant which is about an additional $100 bucks and two of distilled water to do it the right way.
OEM pump and belt and a vacuum job to remove all the air. I use a very experienced shop in Tempe AZ and have been more than satisfied with their work for the last 10 years. As MYC2SPC said, it's a flat rate of 4 hours and at $100 an hour the numbers add up. Sun Coast sells the pump and gasket for less than $300. Can't remember the individual drive belt cost, but it's not that much.
