Water Pump
Old 07-03-2015 | 12:16 PM
MYC2SPC's Avatar
MYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really niceMYC2SPC is just really nice
Water Pump
I have an 06 C2S with 40678 miles and a 5 year 60,000 miles Fidelity Platinum warranty. My water pump is going. I've read lots of threads of people changing them out around 40,000 miles. My question is, were any of you able to get a replacement through your warranty or through Porsche? I gather this will be out of pocket expenses. I would appreciate any thoughts! Thank you and Happy 4th of July!!!
Old 07-03-2015 | 01:47 PM
MYC2SPC's Avatar
Cancel my question! I like a dummy read under the engine coverage section not the cooling section at first and low & behold water pump,thermostat both covered. I finally for the first time get to use my warranty!
Old 07-05-2015 | 08:21 AM
DJSArcade's Avatar
DJSArcade is infamous around these parts
My (2010 997.2) water pump started to die around 34k with the tell tale "whistling" sound at idle that goes away immediately when the gas is tapped.
It was covered under CPO warranty, thankfully!
This is the only "major" fault I've had with the car, too.
Old 07-06-2015 | 05:20 PM
Gary B's Avatar
Gary B has a spectacular aura aboutGary B has a spectacular aura about
Okay, I'll ask... Other than the obvious puddle of water under the rear, how will one know the pump is starting to fail? My 2006 C2S just turned 40,000 miles. What are the warning signs?
Old 07-06-2015 | 07:26 PM
OldBoldPilot's Avatar
OldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond reputeOldBoldPilot has a reputation beyond repute
I just had mine replaced last week, three weeks before the CPO expires, with 58,000 miles on my '08 C2S cab. Other than an obvious leak, you may hear a whirring sound coming from the vicinity of the pump at idle. It helps if you have a mechanic with acute hearing.
Old 07-07-2015 | 09:03 AM
DJSArcade's Avatar
For me it was a slight whistling sound at idle that went away immediately if I tapped the gas.
Internet diagnosis told me this was water pump, stealership confirmed and replaced under CPO.
Old 07-07-2015 | 03:02 PM
MYC2SPC's Avatar
Mine came with no whistle & hadn't started leaking yet. It was just a little knock going on that you could only hear at idle.Bearing was shot on front pulley!
Old 07-07-2015 | 03:33 PM
porschelady's Avatar
porschelady is just really niceporschelady is just really niceporschelady is just really niceporschelady is just really niceporschelady is just really nice
does anyone know what the approximate cost of replacing the water pump is?
Old 07-07-2015 | 03:46 PM
Buddhamonk's Avatar
Buddhamonk has a spectacular aura aboutBuddhamonk has a spectacular aura aboutBuddhamonk has a spectacular aura about
about $1K at indy shop but a lot less if you do it yourself (not an easy job however)
Old 07-07-2015 | 03:51 PM
thanks. no trouble yet(knock on wood) but this seems a common early failure.
Old 07-07-2015 | 05:20 PM
MYC2SPC's Avatar
Yes about a $1000 unless you have a warranty!
Old 07-09-2015 | 09:29 AM
GBG's Avatar
GBG
GBG is a jewel in the roughGBG is a jewel in the roughGBG is a jewel in the rough
I've been debating whether to replace mine-- no signs of trouble yet but I'm about to hit 60k miles so the consensus seems to be to replace as a preventative measure.
Old 07-09-2015 | 09:41 AM
MYC2SPC's Avatar
Key word "yet". Yep it's probably better to be safe rather than sorry! lol
Old 07-10-2015 | 10:20 PM
carrera997re's Avatar
carrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant future
Water Pump
Are there aftermarket water pumps that are better then OEM or are you guys all going OEM?
Old 07-11-2015 | 09:51 AM
MYC2SPC's Avatar
No leaking whatsoever on mine just the bearing going.
Quick Reply: Water Pump
