Experiencing a loud snapping noise when sunroof
is opened or closed, I’ve looked at the tracks and they seem smooth and clean. so is the plastic wind deflector. ……..any thoughts would be appreciated.
When I had this problem it turned out to be the roof catching on one of the seals. It (the seal) finally broke and the roof jammed. This necessitated the removal of the roof and replacement of the seal that runs around the opening and the one at the rear of the roof. Cost close to 1grand, mostly labor. I had dealer do it because I was concerned about rattles and leaks were it not done right. If the one of or both of the pulleys break add 1700$ to the bill because they have to replace the whole rail/carriage assembly. There are no replaceable parts, as unbelievable as that sounds. I'd stop using it and get it fixed now if I were you.
No joke. Labor intensive job. The origional estimate was for 2700$ Then I was told I was lucky, didn't need to replace rack and carriage. Heh heh.That part goes for 1400 on Suncoast btw. Turned out to be 100 or so for seals and 5+ hours labor. I bit the bullet. Really miss the roof for ventilation and I felt safer letting them do it.
If it breaks and jams you could have water coming in the top. No rattles but I agree it's crazy money. My indie said he used to do a lot of repairs on older cars. Probably coulda saved some money but...
Good luck
Good luck
This happened to me. The roof gasket/seal came loose and jammed my sunroof when trying to close it. Dealer fixed it under warranty but there was a snapping noise that persisted as you describe that was the thin aluminum sunroof cover panel that has the alcantara liner catching on the scissor mechanism that opens the sunroof. I have an appointment to get it replaced next week (took 4 weeks to get the part from Germany since they had to fabricate it). Hopefully the snapping noise goes away.
Yes, they quoted me around $2k if this was not under warranty. Almost all labor costs.
jaehoppa
10-22-2015 09:17 PM
