997.2s with 5000mi. Clunk noise up front?
This clunk noise is most noticeable when traveling at slower speeds and when the left front wheel hits bumps, sound like a large component is loose in front of the steering wheel at waist level or above.
Shop diagnosed the issue being the lower steering shaft and I located a used on and the installed it for $300. Plus $50. For the diagnosis.
This did not eliminate the clunk noise so I will be retuning it, after spending $350 to R&R the wrong part what should I expect the service shop to do for me?
Do I keep paying if the service does not correct the problem??
Is the bump stop located on the top of the front strut/shock
How can I tell if that's the problem, sounds like it forward of the steering column or above my knees.
