Front calliper rebuild?? 997.1
Old 03-22-2016 | 05:38 PM
Storman's Avatar
Storman is infamous around these parts
Originally Posted by floatingkiwi
Hey all - to remove the front calipers, where can you pinch the line to stop all the fluid coming out? My lines are very hard as though they are plastic rather than rubber. Ideas?
I used a pencil sharpener and sharpened a piece of wood, then lined it with a couple layers of latex glove. Used it as a plug!!
Old 03-22-2016 | 05:59 PM
Storman's Avatar
Oh ya,,,I flattened the tip slightly on the piece of wood. You do not want it to go through the rubber glove [latex]. Hope that helps!
Old 05-16-2016 | 05:30 PM
Storman's Avatar
Cool Brakes done
Just thought I would touch base with everyone about the front damper seized. I
cleaned up both ends of the damper as well as the rest of the dampers front and back. Added some very thin double sided tape [This tape was clear when the covers were removed] to the areas that had adhesive before.
Re $ re front / back rotors and pads from stop tech [street performance].Replaced brake fluid. Bedded the pads as per instructions from stoptech.
Braking as good as stock or better. Note, I do not race the car it is a daily driver. 2007 C4S The brake dust is the same as stock.
It has been a month now and no squeeks at all. I paid half the price for parts compared to direct from Porsche.
Thanks again for your input!!
CHEERS!!
OCT
03-29-2016 11:04 AM
xmaciek82x
03-18-2016 04:51 PM
terminal_ac
02-26-2016 03:37 PM
RacingBrake
02-19-2016 06:31 PM
Quick Reply: Front calliper rebuild?? 997.1
