White Smoke - Right Side Exhaust
Old 02-02-2018 | 08:51 PM
gonz996's Avatar
gonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond reputegonz996 has a reputation beyond repute
I have a 997.1 S with 72K miles. I drive very short distances to and from work since moving to OKC from San Antonio - ~ 5 miles, and this has been since May of 2017. Today, as usual I drove to work, never take the car over 2K to 3K RPM while cold. I drove home from work, oil still not at temp. I took her back out to pick up a pizza - still cold. Hours later, I started her up only to see white smoke in the garage. It dissipated, but wondering why that would be? She had an oil change 3 months ago, and according to the sensor there's no change in level.
I never take the car over 3K when the engine oil is cold.
Thoughts?
Old 02-03-2018 | 07:40 AM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
All those short trips are filling the oil with condensed water and what you probably l saw was steam on that last start. Open your oil fill cap and see if there's a bunch of yellowish foam in there. If so, that's a frothed oil and water mixture. You need yo take the far for a good hour long trip to burn this off, then also check your oil as that water in there will give you a false oil level read.
Old 02-03-2018 | 10:58 AM
gonz996's Avatar
Thoughts?
Thanks for your response. I checked the oil cap and pipe and there’s some yellow buildup. I took the car out for a drive, smoked at start up and went away; drive ~ 40 minutes on highway. The idle was a little high and slightly high; I got a code to take car to the shop. I had to add fuel and opted to not turn the car off; call Porsche to let them know I was going to drop it off for diagnostics and repair, and after leaving station it started smoking again then stopped smoking. Ugh
Old 02-03-2018 | 11:05 AM
Petza914's Avatar
is it smoking more out one side of exhaust than the other? Is there more soot build up on the tips on one side or the other? Left side soot or smoke is an indication of bore scoring
Can you remove the oil fill cap with the engine running or is there so much vacuum it feels glued on - this is a symptom of s failed AOS which could result in smoke out the exhaust. If you've done a lot of short trips where the oil level in the crankcase has raised enough to be too high because of the water mixed with it, an overfull oil condition can cause premature AOS failure. I'm sorry to say that those short trips are very bad for this particular motor.
Old 02-03-2018 | 11:08 AM
gonz996's Avatar
One item on driving practices - while oil is under 200, I never rev the car past 3K. Given my short driving distances the only thing I recall prior to the initial engine smoke incident was short shifting up to 2.5k with throttling. Speaking to a tech he said there could be excess gas in a cylinder, or another possibility is the oil separator (can't recall exact reference to part that has a plastic bladder) that's a known issue. The issue with cylinder scoring I'm not sure is a factor given the car is never pressed when the oil is cold. The car otherwise has no oil usage or smoking and maintained oil changes every 6 months.
Old 02-03-2018 | 11:12 AM
gonz996's Avatar
I dropped the car off at Porsche and they'll have a tech inspect it on Monday. I think there was more smoke on the right side, but it's hard for me to tell as when it occurred at start up it was very short in duration. I don't know there's a lot of soot other than the inside of the exhaust tips have always been dark
Old 02-03-2018 | 11:27 AM
Petza914's Avatar
on a .1, you're hoping for right side smoke, not left as the bores that usually score are on the right side of the motor, but because the cats crossover to the other side, the right side cylinders exit out the left exhaust tip, providing you're running a stock exhaust setup, which would make a failed AOS the likely culprit of the smoke.
​​​​You say you don't have oil use, but if the water is mixing with the oil, the level will look fine even though the oil is low.
Interested to get Monday's report.
Old 02-03-2018 | 11:35 AM
gonz996's Avatar
What I noticed on the first occurrence last night was smoke out the right side while in the garage. The oil was also last changed in September I think and it's always been just slightly under the top of the scale - no movement, but I get what you're stating, although if it was building with water then it would be all the way to the top and the car hasn't otherwise previously smoked at all.
By the way, can you tell me what the AOS is, and is it a major part and/or replacement in terms of labor?
Old 02-03-2018 | 11:41 AM
gonz996's Avatar
I found it - search is a good thing - Air Oil Separator. I also noted you had a motorsports AOS for sale back in '12. This could be what the technician was referring to. Anxious for Monday and hoping for nothing worse than this.
Old 02-03-2018 | 11:58 AM
Tarek307's Avatar
Tarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond repute
Don't worry yourself, it will be something silly like AOS..all this bore score nightmare scenario is a very unlikely outcome.
Old 02-03-2018 | 12:02 PM
gonz996's Avatar
Thanks. Given all things considered I’d like to think if it was something major it would smoke all the time. I’ve research the AOS now and I see it’s rather common. I’m still wondering why it would throw a code - I’ll undoubtably find out Monday.
Old 02-05-2018 | 01:14 PM
gonz996's Avatar
I heard back from the Porsche service and it’s the AOS. They also need to replace spark plugs as a result of the oil. $1725. Ugh. They did say it could have been much worse and fortunate not much time passed < 1 day.
Ugh
Old 02-06-2018 | 12:31 PM
Tarek307's Avatar
Ugh
Great news! sometimes with all the scare mongering we are too worried, couple of months ago my car cut off while driving, i knew i was low on gas..so went and got gas in a can and put in and it still wouldn't start..i thought thats it..IMS blew..lol, had it towed to mechanic and all it needed was just 2 gallon gas can instead of the 1 gallon i put in lol..
Old 02-06-2018 | 12:35 PM
gonz996's Avatar
Thanks. I really feared the worse especially with similar issues resulting in a need for an engine rebuild, so the result truly is “Great news”!
Old 02-13-2018 | 02:53 PM
crazycarlitos's Avatar
crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !
Sometimes u will get white smoke on startup if u parked at an incline....
Quick Reply: White Smoke - Right Side Exhaust
