When a 997 cab was simply not enough...
Originally Posted by PorscheC4
Why not just put some gt35r's or gt40r's on the stock 997S 3.8 ltr motor? why buy a 996TT motor and bore it out(assuming your bored it out)?
Comparing an NA 3.6 to a TT3.6 is apples to oranges. Not to offend anyone, but one motor costs over 3X the other...They are both great motors for their intended application. The 3.8 M97 is no different.
The Displacemnet increase is done to keep drivability and smooth power delivery/low lag. Sure massive turbos can make 1000HP...but with massive lag!
Also, for reliability puposes - the max boost is 1.2-1.3bar. The combination of larger displacement, larger turbos, cams and custom ECU work all contribute to a powerful - yet tractable, reliable motor. There's a lot of different ways to accomplish a given goal.
This is 9ff's solution for their clients who require a high HP car devoid of large wings, scoops etc. This car is all about stealth - you dont drive an enzo to run to the store in the middle of the night, or pick your kid up from school...or to the doctor's parking lot! Leave it at home!
Originally Posted by 2thfixr
How are the intercoolers getting enough air flow? Ducting from the wheel wells?
"Each type of intercooler has its strength and weakness. Air-to-air units tend to require longer ducting to route the air from the turbo through the intercooler then back to the engine; this extra tubing might increase lag slightly on some engines and may also present interesting packaging challenges. Air-to-water units, however, can have significantly shorter intake plumbing; the intercooler can be placed in hot underhood areas where no airflow is present since the liquid coolant circulates to its radiator. This allows for simpler installation but at an expense of reduced cooling efficiency. Note that both kinds cool better when air is flowing through the intercooler (air-to-air) or the radiator (air-to-water); both kinds can benefit from the installation of a fan for low-speed operation."
- Dempsey's turbocharging 101 page.
Originally Posted by ECB
This is a 9ff 4.0L 780HP motor and conversion...not an "EVO8000"
The complete conversion is ~$120k...I know, I know - why do that when all you need is a "MO-V-FLOW, a flash and some stickers...?"
If you have to ask...
let's see...100K for a nicely optioned 997 cab. another 120K to mod it. $220K. i don't know.... the stealth part of it is cool, but for $220K i'd think i'd want something that at least looked the part too. falls into a weird price niche as there aren't any high HP cabs in that price range so i guess it's a bargain compared to a murci spyder, cgt, or f430 spyder.
neat project regardless.
Originally Posted by deputydog95
i know this isn't an evo product, i was commenting that they also do an 800 HP 3.6 liter TT motor buildup as well.
For that $220k...you'll have an cab that will *** rape (with no lube) any other cab short of a Zonda F. Granted, nobody does this for "value", but the most common client already has an enzo/zonda/murci etc.. that has the "presence" that no porshce (sorry CGT) ever will. They just need something practical, invisible but FAST.
see Andrew, you got it!
Whoa, I want one! That thing is sick. 9ff makes just amazing stuff, nobody would question a Ruf of the same type of flavor, it's for the very same type of customer that purchases a Ruf. Very nice work ECB.
A stock 415HO 3.6TT is $30k from Porsche....REAL HP costs money.
How much for a fully engineered, built and installed low volume 4.0L 780HP motor...?
There are a lot of EVO cars out there running around (very quickly), and we don't appear to be seeing grenading motors, so maybe you could clarify your intent.
