AIRBOX / INTAKE DIY - Helmholz resonator bypass
Old 10-13-2007, 03:07 PM
JCS's Avatar
JCS
JCS is offline
JCS is infamous around these parts
Originally Posted by Gcalo
Ok so what you are saying is that there is effectively less resistance in the smooth pipe. No?
I might try this on my 360.
What's the reference to the $250?
Many thanks.
That's correct. A smooth interior pipe will have less resistance thru it than a rough one . How much ? that will depend on the actual roughness .
Since the Porsche hose is smooth except for a few indentations, I assumed 20 % less .
But even if it were 100% less , it would still be insignificant .
I'm not sure if I would call a less than 0.1 hp gain " effective " . Lol
$250 is what Fabspeed charges for their " cold air " intake rubber elbow .
  #47
Old 10-13-2007, 04:25 PM
Gcalo's Avatar
Gcalo is a jewel in the roughGcalo is a jewel in the roughGcalo is a jewel in the rough
Ok I got it all and thanks for taking the time. All makes sense.
$250.00 is a lot of cash for a small pipe!
many thanks again.
BTW, do all 997's come with this air box resonator assembly?
  #48
Old 01-05-2008, 06:48 PM
rah79's Avatar
rah79 is infamous around these parts
JCS,
For a guy from NJ you are all right.
Whats that mean? NJ is the $hiT
only the strong survive
Yes I believe they all come with a resonator
  #49
Old 01-05-2008, 07:31 PM
666666's Avatar
666666 is infamous around these parts
Just bought my hose its 4ply silicone 500 degree resistant (not that ill reach that, i hope) it cost me $30
  #50
Old 01-05-2008, 07:44 PM
lardog's Avatar
lardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to all
[quote=rah79;1581287][quote=Gcalo;1397656]JCS,
WHAT???????????
  #51
Old 01-05-2008, 09:04 PM
ak996TT's Avatar
ak996TT is infamous around these parts
very interesting.....let me start looking into it..
  #52
Old 01-22-2008, 12:03 PM
VTach's Avatar
VTach is infamous around these parts
Thumbs down credit card fraud
Originally Posted by mdrums
I have found these places that sell the Silicone hose like Fabspeed uses:
http://www.hightempsilicone.com/
http://www.sporthoses.com/
http://www.stylinmotors.com/index.html
FYI,
http://www.hightempsilicone.com/ is apparently out of business...Their phone is disconnected and not responding to emails. My CC was charged on the 6th but no product delivered.
Elastofab is company listed on CC statement and is also bogus!
Live and learn.
  #53
Old 01-22-2008, 03:45 PM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
Originally Posted by VTach
FYI,
Live and learn.
Yikes...sorry about that. Back then I just posted a bunch of website I found that sell silicone hose. I just use the stock airbox myself.
  #54
Old 01-23-2008, 02:41 PM
997SFighter's Avatar
997SFighter is infamous around these parts
FYI,
Live and learn.
Same story with me, I called Hitemp. and they were out of business but still got dinged the $38.
  #55
Old 01-23-2008, 04:53 PM
Gcalo's Avatar
FYI,
Live and learn.
Call your CC provider and dispute the charge.
You have 60 days from the charge date to do so.
  #56
Old 04-02-2008, 08:22 PM
pcarr's Avatar
pcarr is infamous around these parts
Crod,
Wonder how your mod is holding up? Are you still using it?
  #57
Old 06-19-2008, 12:43 AM
Porschedeisgn's Avatar
Porschedeisgn is infamous around these parts
hmm this is new to me,.. may i ask what this mod does?.. seems like it alters the intake and presumably more sound is obtained.. ?
  #58
Old 06-19-2008, 05:32 PM
JCS's Avatar
JCS
JCS is offline
The 997 air filter box has a resonator built into it .
It's purpose is to alter the sound coming from the engine .
The outlet of the resonator connects to the main air intake hose to the engine ( see red arrow in picture )
As the outside air ,on it's way from the filter to the engine inlet , is drawn past the resonator , it creates a sound frequency which cancels out some of the engine noise ( since similar frequencies tend to cancel each other)
If you want to know how it works, blow over the top of a bottle .
Depending on the volume of the bottle and the velocity over the outlet , the frequency changes (the Helmholtz principle )
The resonator outlet has a vacuum activated butterfly valve in it which closes at high rpm's , thereby disabling the resonator effect , and is open at lower rpm's.
If you want your engine to sound a bit more aggressive at lower rpm's, all you need do is to disable the resonator .
It will not do anything for performance, but it sounds cool . A bit like a mild performance muffler .
Some do it by replacing the OEM air intake hose with a rubber elbow from a plumbing supply place, or as I have done, just put a plug into the resonator hose ( see previous threads )
If you go the hose replacement route , be sure to put a cap over the resonator outlet to prevent dirt from accumulating inside
Or, you can buy the Fabspeed "cold air kit " for a little over $200 .
You will receive a pretty red rubber elbow and , according to Fabspeed , get at least a 10 hp gain to boot . Lol
  #59
Old 06-19-2008, 07:35 PM
Cattman's Avatar
Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !
One option I've not seen discussed, but which should work would be to unplug the vacuum tube that connects the Helmholz resonator to the vacuum solenoid, and plug the vacuum solenoid with a $.02 vacuum cap. I wasn't sure what size I needed so bought a multi-pack from Auto-zone for $.99.
Capping the vacuum solenoid is a necessary step when removing the OEM airbox and installing an EVOMS box, so I don't see why it wouldn't work to just stop the suction from activating the resonator if using the stock box.
Am I the winner of the cheapest solution contest?
  #60
Old 06-20-2008, 06:21 PM
vrnkc's Avatar
vrnkc is infamous around these parts
My modification
Used parts found at OSH
Quick Reply: AIRBOX / INTAKE DIY - Helmholz resonator bypass
