APS TT Z06 (Cartek Tune)
Here are a few pictures of my Cartek tuned APS TT Z06, 652whp and 624rwtq @6lbs of boost. I just installed a Pfadt coilover suspension and sway bar package and the car is on rails. The person I bought the car from had the car shipped to APS in Australia where they did everything, this is the actual car on the airpowersystems.com website. After purchasing the car I took it to Cartek for a full inspection and retune and extracted a few more horses.
Here is a list of the package:
- Twin 600 HP GT3582R true ball bearing liquid cooled turbochargers for bulletproof boost
- Custom APS Turbocharger end housings for extreme efficiency and in a super compact package
- Twin huge 44mm TIAL external wastegates for rock-steady boost pressure
- Extreme Performance Twin Pump, Full Return, Constant Differential Pressure Fuel System for Ultra High horsepower at high boost pressures
- Teflon lined stainless steel braided fuel lines for high fuel flow and added protection
- Mandrel formed and TIG welded 304 grade stainless steel twin 3" exhaust system for huge horsepower and a symphony of turbocharged sound
- Extreme Duty APS engine oil cooler for total peace of mind
- Twin APS vertical flow bar and plate intercoolers for massive levels of chilled charge air
- Twin APS air intakes for free and easy breathing
- Twin APS dual vent blow off valves for the ultimate in boost response
- No cutting of stock body for peace of mind
- Inconel turbine wheel and Ni-Resist turbine housing for the ultimate in high exhaust gas temperature longevity
- Hi Performance Gasoline Spec turbochargers completely eliminates the limitations of regular diesel spec turbochargers commonly found in aftermarket turbo systems
Tony sick as hell man, have you had much time in the car at all, how is it? I was in Raudels Z06 and it was pretty crazy, well he made it crazy cause he's crazy LOLLLL!
Hope all is well man.
Martin, how are you man? I'm doing well thanks. It's impressive how hard this thing pull's compared to my 996TT. Totally different from the 996 also, I kind of miss my 996TT but this car is a blast.
Awesome man, I want a ride next time we meet up, there will probably be another ER run in November
How do you get the car to put the power down to wheels without spinning through all the gears? Planning to run some wider stickier tires on it?
Great looking car btw.
