Modded 2009 ZR1 Video: 581 rwhp & 599 rw tq
Old 01-07-2009 | 07:48 PM
HennesseyPerformance's Avatar
HennesseyPerformance is a splendid one to beholdHennesseyPerformance is a splendid one to beholdHennesseyPerformance is a splendid one to beholdHennesseyPerformance is a splendid one to beholdHennesseyPerformance is a splendid one to beholdHennesseyPerformance is a splendid one to behold
http://www.youtube.com/watch?v=Vva9IeaXil0
Old 01-08-2009 | 08:21 AM
TT 955's Avatar
TT 955 is infamous around these parts
Originally Posted by HennesseyPerformance
not working
Old 01-08-2009 | 09:01 AM
Originally Posted by TT 955
not working
thx. fixed it:
[media]http://www.youtube.com/watch?v=Vva9IeaXil0[/media]
Old 01-08-2009 | 12:45 PM
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
Good numbers.
Old 01-08-2009 | 01:52 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
ZR700? So you're using a drivetrain loss of 17%?
This is only a gain of 60 hp over stock (less than 10% increase).... how much does this kit cost?
Old 01-08-2009 | 04:31 PM
SINISTR's Avatar
SINISTR has a spectacular aura aboutSINISTR has a spectacular aura aboutSINISTR has a spectacular aura about
17% loss is way to high for that car.
Old 01-08-2009 | 06:40 PM
ORYX's Avatar
ORYX has much to be proud ofORYX has much to be proud ofORYX has much to be proud ofORYX has much to be proud ofORYX has much to be proud ofORYX has much to be proud ofORYX has much to be proud ofORYX has much to be proud ofORYX has much to be proud of
Usual calculated loss is 12-13%. Which works out to about 668 hp with a 13% loss, still not a bad increase. I'm sure there is still quite a bit more in it.
Old 01-08-2009 | 07:36 PM
Almo's Avatar
Almo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant future
15% to 17% should be right on the money. Gain with the numbers across the curve look great.
Old 01-08-2009 | 07:41 PM
flash68's Avatar
Based on what? We aren't talking about a Turbo 400 tranny here.
The stock dyno #s I have seen are falling between 560 and 570 at the rear wheels. That puts loss between 11-13%.
Old 01-08-2009 | 07:48 PM
richtor's Avatar
richtor is infamous around these parts
Originally Posted by flash68
Based on what? The stock dyno #s I have seen are falling between 560 and 570 at the rear wheels. That puts loss between 11-13%.
there is a lot less loss with the rear mounted tranny the vettes have. 10-13% sounds very accurate.
Old 01-08-2009 | 10:13 PM
th3Stig's Avatar
th3Stig is a glorious beacon of lightth3Stig is a glorious beacon of lightth3Stig is a glorious beacon of lightth3Stig is a glorious beacon of lightth3Stig is a glorious beacon of light
This is just the low-avg numbers from their dyno pulls. It's called marketing... underadvertise, overperform.
Hennessey, what kind of numbers are coming from the LS9 Camaro y'all got?
Old 01-08-2009 | 10:53 PM
flash68's Avatar
Old 01-09-2009 | 03:05 AM
Almo's Avatar
Which dyno? I haven't seen numbers that high.
Old 01-09-2009 | 03:40 AM
flash68's Avatar
Here's a quick list of some search results. I have seen anywhere from 530s to 570s, but more in the upper part of that range it seems.
Bottom line, no matter what the varying numbers are, 17% drivetrain loss on a newer manual tranny is exaggerated.
Dyno-jet
12.3% loss on this one.
These guys said they just tinkered with it, no add-on parts or anything
Old 01-09-2009 | 03:52 AM
Almo's Avatar
Dyno-jet
I still think 15% is right on the money in my opinion. Viarable 2% might be the cars are running a bit rich. I have yet to see stock numbers over 550. (520 to 540s). Getting ready to check all your threads out though. From what I have read... tinkered with it isn't showing SAE engine dyno through the wheels on a Dyno Jet. They're hitting the street a bit rich so tinkering could be, adding a couple degrees and leaning it out and getting a quick 40 to the wheels. Perfect example based off what your saying is this thread... 581, MODDED puts the cars at your stated DT loss.
Quick Reply: Modded 2009 ZR1 Video: 581 rwhp & 599 rw tq
