My Low-Key Malibu
#31
Continuing the build up into the top end:
To avoid any valvespring issues with high boost, I upgraded to the Pacalloy springs which will give me about 700lbs at full lift:
Had the valvecovers hard anodized, polished the oil filler caps and had them black anodized:
I put the custom thickness Cometic head gaskets (.051") down, slipped the heads on and slowly torqued them down. The next morning I loosened them a bit and retorqued, then I installed the T&D shaft rocker setup and roughly set the valve lash so I could check the shaft stand height and ensure the rocker arm tip sweep was acceptable:
Since the sweep was narrow and not too close to the edge, the stands didn't require machining, so I used High Tack to glue down the Felpro intake manifold gaskets. Then I put the manifold on and torqued it down slowly and left it overnight.
The next day, the High Tack was dry when I removed the manifold. The I trimmed the intake manifold gasket to fit the AFR 235cc ports:
With the heads and intake manifold gaskets finished, I could final port-match the intake manifold just a tiny bit smaller than the AFR intake ports:
In October I took a class on Powdercoating & Sandblasting at the TechShop, to get ready to finish my intake manifold. I had it clear anodized then Teflon coated first (for alcohol protection) then masked off the inside and re-blasted the outside. Here it is masked and plugged, ready for me to powdercoat:
Here I am applying the powder. The clear goes on white so you can see what you are doing:
Here it is right out of the oven after baking at 380F for 15 minutes:
And here's a closeup before I removed the plugs:
More on the way tonight.
Jim
Jim
#32
With hard anodized Cloyes timing cover on (with a Cloyes Hex-A-Just timing set underneath), oil pan all sealed up, ATI damper on:
On to some graphics. I had planned for this so I prepared 4 oil filler caps.
I took a class on the Laser Cutter/Etcher then designed some graphics and font for the two sets of oil caps.
Two caps I did with the real motor size and blower model:
And the other two caps I prepared for Saturday night fun and confusion
Then it was time to epoxy in the nitrous spraybar. It's a NOS Big Shot that I cut up to embed in the manifold since I need that height to be able to use the stock flat hood. Once it was dry I used the vertical mill to surface it flush, then I drilled a 3/32" hole and installed a spring roll pin so the spraybar can never blow out.
This last weekend I used Corel Draw to design a flame font and adapt a ghost logo for my valvecovers.
Here's a closeup - it looks a bit tilted but that's just the picture:
And here's an overall shot of how it looks today (I have some trimming to do on a few intake manifold washers hence the missing ones):
Where the distributor would normally be you can see the sequential injection cam sync unit. I powdercoated the top of it flat black. All the powder I have used so far is automotive-rated for underhood use.
Lots of stuff still to do:
From left: Custom 10-rib, 9.2" crank pulley from ASP Racing, AC delete panel I will mount the new Holley Dominator EFI unit to, Holley Distributor-less Ignition System, about 1/5 of the wiring harness I will eventually install.
Stay tuned.
Jim
Stay tuned.
Jim
#39
Thanks! Unfortunately I should have doled out the pictures - I sent out so many at once they shut down my website mid-month (until Jan1) because I exceeded my bandwidth.
I will hopefully have some new shots by then to share (in smaller doses ).
Jim
Jim
