Chrysler 300c w/ JDM & DTM roots
#106
Here is the rear window switch after a mild wetsand. Just needs a little bit more sanding and then some cleaning up on the inside corners etc before I lay the clearcoat and do more sanding.
This is the driver side seat backing. The passenger side was my guinea pig and I learned a lot from it so the driver side should be cleaner an the fabric should be much tighter from the extra prep work I did for it.
WheelB
07-06-2018 11:16 AM
2010, 300, billet, challenger, chrysler, cigarette, coil, covers, lighter, matchbox, mini, pack, projectors, technology, valve
