How many of you are running with fuse 22 pulled?
I have not read anything long term - thinking no one has kept it pulled for that long. The other easy "fix" is disconnect the vacuum tubes running to the switch valve (actually on the exhaust - you can see them under the car) and leave fuse 22 connected. You will not get the mixture issue, you may loose a little low end torque - but the sound is open at all RPMs like it was above 4500 RPM when connected. The switch is open and the vacuum closes it - kinda backwords logic - unless you design it this way for a reason !!!
I did this "disconnect" thing for awhile (12 months) - then went w/ RSC mods including a Quicksilver exhaust. You will find Quicksilver/Tubi/Gruppe B do not have a vacuum connection on their exhausts for AM.
I can see the black vacuum line connected to the exhaust on the drivers side but I am having difficulty locating the one on the passenger side. I think it is located more on the top of the exhaust and slightly out of view. Is this correct? If so, is it difficult to just reach up there and disconnect the black line?
TIA,
Adam
Yes - sounds like you are correct, it is up there and can be done by hand. If you had the exhaust removed (and you do not need too for disconnect) you would see that the passenger/driver sides are slightly offset in rotation but the units (round shape, silver color aluminum, nozzle sticks out that hose goes on - kinda like an aquarium air hose connecting on to the air pump) on the "top" of exhaust are the same pieces and would disconnect the same way. That is a lot of words for yes, in slightly different places. Would probably be a lot easier to disconnect if up on a lift (or maybe a jack?) - cars are just sitting low. Just make sure car has not been run for several hours !!!
Also - just a note, my RSC Quicksilver exhaust sounds even better than disconnected stock ... but this gives you an idea. The stock exhaust is extremely "packed" and inefficient.
Excellent! Thanks for the detailed info. Much appreciated. I will put the car on a lift to get at the passenger side. I plan to get an exhaust but would like to get the feel for how it will sound first.
I just got the car on Saturday so I need to wait a few weeks before I make another large purchase or the wife will toss me out. I am assuming the exhaust will cost around $3,500 installed.
Adam
Angel
Thanks for your input though my understanding is that disconnecting the tubes (as I did yesterday) provides the same sound effect as pulling the fuse. I'm glad you don't have any issues with pulling the fuse although some are warning about the possibility of getting an error code on your computer.
What I noticed is that I now get that rumble a little under 3k RPM as opposed to above 4k RPM.
they said at the dealership it doesn't make a difference, since the valves aren't opening or closing anymore since there aren't any valves anymore anyway, using a sports exhaust like a quicksilver.
