Anybody Install Aftermarket Exhaust Themself?
I am thinking of purchasing an aftermarket exhaust. I assume this is a relatively easy bolt-on process. I am not doing the cats at this time simply the rear box. I am pretty mechanically inclined and have access to a lift. Anyone install a Quicksilver or the like themselves? It seems pretty easy. My dealer wants $450 for the install but I honestly enjoy doing some of the work myself. Any tips or tricks?
TIA,
Adam
TIA,
Adam
TIA,
Adam
TIA,
Adam
It is a relatively easy thing to do. There are a couple of advantages in working through a dealer but provided you have an adequate set of tools and the space to do it you shouldn't find it too hard. I'm by no means a professional mechanic but I would be comfortable doing an install myself. There are one or two little tricks and you sometimes need to adjust the tips a couple of times to get them perfect but it's not rocket science.
I wouldn't advocate anyone doing this themselves until I was familiar with their level of experience but if you drop me a PM I'd be happy to guide you through the install process on an RSC system.
Easy installation.....
HI Adam.....installed the Quicksilver on my car twice, the "SuperSports" was too loud so I exchanged it for the "Sport". You should have no problem.....need torx drivers for the pan, sockets, wrench.....some patience. Oh and heat the gaskets with a propane torch to make them easier to remove from your existing exhaust.
Scott
Scott
Scott
Scott
Cool. I have all of the above in my tool box. Sounds like it will be easy. Thanks for the response.
Adam
PenguiN
04-22-2021 07:33 PM
oddjob142
08-19-2015 12:27 PM
