Gear Box Remap
Thanks,
Adam
I sent mine to paramount. RSC sends the chip to the UK as well. So I figured if it is the same program, I would minimize the chance of something happening in shipment with one less trip. Paramount also did my ECU. I think the net cost for both was around $1850. I had an Aston tech that I am friends with pull my chips. It took around 30 mins. You have to take off the tire to pull the ECU but the shift chip is in the trunk and is easier. The shifting change is more significant than the ECU. I do fell more torque and better acceleration but the response in the shifting is much better. What I've learned is that the shift happens a lot faster in the depression of the paddle. So you are in gear up or down faster with out pulling the paddle all the way to the column. Shipping was easy. Paramount gives you all of the info you need and if you go to a Fed ex local with experience in over seas transport it will be no problem. My chips took about 5 days to get back because it got their on a Thursday. and Monday was a holiday in England. When you ship it, for customs it should be listed as a warrantied repair. I would definitely do it again. I have a quicksilver exhaust and K&N filters on the car as well and I think even with out the sports cats, I am close or equal to a 4.7.
Just so you know, you don't have to ship your ECU to RSC twice, just once to our office in the UK.
So if we purchase the TCU remap from you do we ship it directly to Paramount? Is your software the same as Paramount? Any differences?
Also, do you have any literature on how to remove the TCU and ECU?
Thanks,
Adam
If you purchase the TCU from RSC you just send it directly to our UK office:
RSC Tuning Europe
Lakeside, Shillinglee
Godalming, Surrey
United Kingdom
GU8 4SX
We remap it and send it back. The TCU on the Vantage is behind the trunk liner on the right-hand side along the fender. Pretty easy to get at and remove, just unscrew the retainers and unplug. As with the engine ECU, it's important that you don't turn the ignition on once you have removed it, until it is back in situ, plugged in and secured.
The other important thing is that whoever removes and packs it (I'm assuming you'll do your own based on your mechanical ability) labels it clearly - "Automotive ECU - Return and Repair." If it is labelled otherwise UK customs will try to charge import tax.
If you're not happy with the results, I'll refund your money and return to the OE map no questions asked.
Drop me an email if you want to go ahead and I'll look after everything.
Hi Adam,
RSC Tuning Europe
Godalming, Surrey
United Kingdom
GU8 4SX
RSC Tuning Europe
Godalming, Surrey
United Kingdom
GU8 4SX
Adam
PM me and I'll sort you out with a special Thanksgiving deal. You're going to love this one!
jaehoppa
10-22-2015 09:17 PM
proTUNING Freaks
09-15-2015 07:28 AM
albert@velosdesignwerks
09-03-2015 11:11 PM
