any way to remove check engine sign ???
Then you need to pick up one of those OBD code readers with the "erase" feature.
They go for about $300 in stores, and about $150 on ebay.
Plug it in, read the code. If it's "just" the O2 sensor, then you can go ahead and erase it. I'd fix it at some point though, either at the dealer or some garage.
My emissions light goes off at random every few months ... after about 3 starts it goes away. initially had it checked at dealer - nothing wrong w/ system. This is the only "fault" I have and can live with it (most likely my modded cat/exhaust/airbox throws a curve occasionaly and then ECU figures it out).
Mini George
07-29-2019 12:20 PM
Mini George
01-18-2016 09:16 PM
tropicatango
10-14-2015 11:32 PM
