Optimization admisson air Vantage
Old 07-05-2010, 04:06 PM
vince_1972's Avatar
vince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nice
Then I put a neoprene sleeve surrounded by a highly flexible skeleton son metal. Suitable for all curves without crashing and without loss.
and a trumpet of fresh air.
Moves to end of supply duct fresh air.
Material: aluminum.
for a total cost of around 40-50 dollars
Result on this mix:
Old 07-05-2010, 04:08 PM
vince_1972's Avatar
Both:
Old 07-05-2010, 04:15 PM
vince_1972's Avatar
Then, it remains only to fix avecune flange or a bracket to prevent movement of trumpets.
Note: Luckily, my trumpets returning excat between two vertical support of the grid so they perfectly behind plate:
That was more than doubled the intake dynamics of the car. I think the more aggressive grille without distorting the Aston
I hope I was understandable and clear in my explanation
Old 07-05-2010, 11:39 PM
eatnow's Avatar
eatnow is infamous around these parts
What happens when driving in the rain? Any potential problems from getting water in there?
Old 07-06-2010, 04:24 AM
vince_1972's Avatar
I do not think the original system also takes the air directly. In addition, there is a flow in the air box where the water would come up to her
Old 07-06-2010, 01:16 PM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
Are these intakes upstream from the air filters? Put another way, the air that comes in though the intakes passes through the air filters before reaching the engine, correct?
Old 07-06-2010, 01:24 PM
markesq's Avatar
markesq has a spectacular aura aboutmarkesq has a spectacular aura about
I like the idea. I would like to see you run the tube straight with a filter instead of merging into the existing tube.
Old 07-06-2010, 02:03 PM
vince_1972's Avatar
of course
Old 07-06-2010, 02:04 PM
vince_1972's Avatar
a another tube directelly on the airboxe?
Old 07-06-2010, 04:13 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
Very cool idea. I am going to take a peak under the hood soon and do a little investigative work. Well done!
Adam
Old 07-06-2010, 08:37 PM
markesq's Avatar
I did not realize that the filter are after these tubes. Still wondering if anyone has run the filters without the boxes.
Old 07-07-2010, 08:03 PM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
Oh Yes!
Old 07-08-2010, 08:58 AM
Michael 996TT's Avatar
Michael 996TT is infamous around these parts
Very nice ideas! More air is always good ! I love to read how folks are modding their cars. My only thought is all parts being "black" to provide a more slick/don't see look but that is just my opinion ...
Old 07-08-2010, 09:08 AM
RPVantage's Avatar
RPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to behold
Correct me if I'm wrong but I think this new system is sucking air without air filters, right?
( the air filters are at the bottom of the car and the holes are closer to the intake )
ZedEx's Avatar
ZedEx is infamous around these parts
A company called BPi (Bryan Pendleton Initiatives) produces 3.00" inner/6.00" outer diameter and 3.50" inner/6.00" outer diameter ABS plastic velocity stacks. I typically sell these for intake systems fitted with an RF-1048 K&N intake filter, but they would work perfectly for this design as well.
Quick Reply: Optimization admisson air Vantage
