Lightweight Wheels research ...
Old 11-23-2010 | 08:05 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Hey guys,
Any good lightweight options out there?
Just a thought,
-007-
Old 11-23-2010 | 08:13 AM
Tahoe M3's Avatar
Tahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really nice
Have you looked at the Prodrive wheels? They advertise them as being 2.5 kg (5.5 lbs) lighter at EACH CORNER than the stock setup, and they are relatively cheap. They are under $4000 for a set of wheels with P Zero Corsas or around $2500 for just the wheels. And they look good.
Old 11-23-2010 | 08:15 AM
Tahoe M3's Avatar
Another pic...I think it's one of the best-looking wheels for the car and I was going to go with them before I decided I needed to go larger for the supercharger. If I was going to stay naturally-aspirated I would have gotten these wheels.
Old 11-23-2010 | 08:16 AM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
There was a thread a while back about wheel weights. From what I recall, the weights of the stock wheels (not the "lightweight" '09 wheels), as well as the stock tires, were really high. I hear you about the location of the weight, but my recollection is that the weight difference between stock and some of the aftermarket wheels was so large that it almost had to make a difference.
Old 11-23-2010 | 08:20 AM
Racer_X's Avatar
Yeah, this is what I remembered (i.e., a huge weight difference). Is there a model name or number for the Prodrive wheels? They do look nice.
Old 11-23-2010 | 03:06 PM
XJRS Owner's Avatar
Well, you could buy some OZ Ultraleggera wheels @ 19.6 lbs each @ $360 each from Tirerack. But they are 18x9. That's what quite a few guys use for the track...light and cheaper rubber to boot.
Old 11-23-2010 | 10:48 PM
XJRS Owner's Avatar
Originally Posted by 007 Vantage
True, but again those wheels are more an import wheel (same with volks & etc)... they are very light but do not fit the character of the car at all. Might just have to go another route for more rotational mass reduction. Seems like the money will be better spent elsewhere and keep the OEM look.
Anyone know exactly how much the spacers weigh? (perhaps stuart can chime in here) ....
OZ an 'import' wheel? I don't agree with that. You can't get more 'euro' than an OZ, considering they are used on all the DTM cars and other racing series. And they look just as 'right' on a Vantage as the OEM wheels. Plus they are a very high quality wheel.
Old 11-24-2010 | 10:06 AM
klittlehale's Avatar
klittlehale is infamous around these parts
The OZ Ultraleggera wheels at 18 inches are significantly lighter than the 19 inch wheels, and you do have more tire options. Yet if you get serious about the track, the 18 inchers prevent you from upgrading your brakes, which is probably one of the most cost effective track upgrades you can do. There are all these trade offs you need to consider when you are looking at these modifications. I plan to stick with my 19 inch wheels, and I have found nothing that is significantly lighter that is not ridiculously expensive ( particularly for track use where broken wheels do occur.)
Old 11-24-2010 | 03:34 PM
watchrabbit's Avatar
watchrabbit is infamous around these parts
How about the OEM ones found on the sports pack? Are supposed to be lighter... Don't know by what margin though...
Old 11-24-2010 | 07:31 PM
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
Wheel alternative
I too looked to reducing the wheel weights of my '07 7 spokers. Evaluating the significant cost of new forged wheels vs. the loss of what I considered the excellent 7 spoke appearance I instead had the wheels stripped and powdercoated satin black. The tech who blasted them complained of his difficult task. He had to remove the thick, durable OE finish, probably 4 or 5 coats, probably urethane. The new coating, a sprayed on plastic powder, melts into the surface. It's thin, but provides outstanding coverage and durability. No doubt there is a weight save, but it's minimal, 1/2# or less a wheel. Bonus features included a solution to our brake dust problem (the dust is still there, but you can't see it) and I like the "race" look. To my mind the car appears tougher, more masculine. A picture will be attached shortly.
Old 11-24-2010 | 07:46 PM
Chris-NJ)'s Avatar
Chris-NJ) is infamous around these parts
Have you contacted RAC/Champion Motorsports?
They can usually make a wheel/design if you can get enough interested parties to justify the manufacturing of a wheel.
Old 11-25-2010 | 12:51 AM
Yes please! I have the 7 spokers for my winter tyres (lightweight ones for summer) and I would have loved to coat them dark grey. I was afraid to ruin the design of the car though and also was worried about the durability...
Old 11-25-2010 | 04:40 PM
flinder's Avatar
As promised, here is the wheel picture. Durability is not an issue with powdercoating. I have darkened 3 sets of wheels,one paint, two powdercoat. Paint chips, powdercoat does not, nor does it fade. The oldest powdercoat set I have is now 12 yrs old and has been handed down to a second car. Total mileage, about 70,000, yet they clean up easily despite their complex lacy spoke design and experiences of a dozen Michigan winters. The Vantage wheels were powdercoated 2 years and 7,000 miles ago. When viewed in person the dark wheels appear to make the car's handsome,tight design even more concise.
PenguiN
11-12-2015 06:24 PM
The Oss
08-24-2015 09:19 PM
Vellano Wheels
08-20-2015 05:06 PM
ModBargains
08-20-2015 01:28 PM
