plastic that covers radio with scratches
any of you can help, I need to know if there is to replace the plastic that covers the radio, in the photo you can see what I need.
plastic material is not glass, is with scratches, please can you know if there as a spare.
alternatively you to answer the following, have tried to polish plastic, have reaped solutions to scratches, all comments are welcome, but need solutions, thanks to all who want to help
05 ASTON MARTIN VANTAGE
Mine actually had dust underneath that plastic piece and the dealer removed the radio and then removed the plastic piece, cleaned and reinstalled. Looks good as new. My guess is you can purchase that part through your AM dealer.
and the plastic in the sun look good??
you did the test, what do you recommend??
plast x?
hello, thanks for your response to the post of scratches in the plastic that covers the radio.
you have had scratches on the plastic then the radio?
polishing with the product x-plast removed all the scratches?
if you see the plastic, when the sun shines on it, you see the scratches?
thanks for your comments
[QUOTE=spainconection;3186583]alguno de vosotros me puede ayudar, necesito saber si hay que cambiar el plastico que cubre la radio, en la foto podéis ver lo que necesito.
El material plástico no es vidrio, tiene rayones, por favor, ¿puede saber si hay un repuesto?
alternativamente te respondo lo siguiente, he intentado pulir plastico, he obtenido soluciones a los rayones, todos los comentarios son bienvenidos, pero necesitan soluciones, gracias a todos los que quieran ayudar
[/QUOTE
Yo can try with Polywatch paste. I had used it in my Omega Speedmaster Hesalite plastic glass and all the scratches were removed....
[/QUOTE
HotRod
09-10-2015 07:17 PM
