Alarm module location?
#91
Just thought I would update you guys in case someone else finds this useful in the future. So I couldn't find any replacement black plastic high-spec tilt Volvo siren YWK500050 or YWK 500070. I ended up buying a metal high-spec tilt FoMoCo siren from a Range Rover 6G9N-19G229-DG. Used examples can be found as cheap as £15 on eBay, although it may be worth swapping out the battery for a new one (and perhaps trying to mount the battery externally so it can be easily replaced and doesn't leak acid and fry the circuit board in few years time). I had to modify the old bracket slightly to make the new-style siren fit but it was very straightforward. Alarm system service message has gone and I tested the siren is working by waving my hand inside the cabin with the car locked and window open.
#92
Don't ask me how I did it because I have no idea
#93
