SILL REAR TAPE avoid impacts stones...ideas
HI, if we look for the area of the rear wings, we will see some plastic stuck, well we can put on top of those plastic,(SILL REAR TAPE ) because the stones are all for it.
I made a little composition and wanted to put ideas to see something similar to what is used.
Please contribute ideas, anyone will be welcome
I had all factory coating removed and installed 3M guard as per picture:
(doubt you can put new vinyl/3m on top of the old)
This provides more than adequate protection for me.
[quote=gekko;3260585]I had all factory coating removed and installed 3M guard as per picture:
(do can't put new vinyl/3m on top of the old)
Why can not put???.... different dimensions .................. ... we repeat measurements of the lower ...
then you have to put all the new 3m.
I had installed by a professional - they used a large sheet, fitted for my car and then cut (carefully) to the shape needed.
This 3M material is designed to go on top of our paint, if you start layering it, you going to see imperfections, plus doubt it stay adhered correctly.
Suggest you find some people in your town that do "Stone Guards" or 3M Installation & they should be able to sort out the car for you. If in doubt, call your dealer, they must have someone they use for clients cars.
That looks like good coverage. Think I need to contact my film guy. Thanks for posting.
