Programming garage door opener
Hi all first post here and proud new owner of a 2008 Vantage V8 coupe
But unfortunately it doesn't come with the owner's manual and would anyone here be kind enough to tell me how to program the garage door opener? Thanks in advance.
1. Press and hold the two outer HomeLink buttons, releasing only when the HomeLink LED begins to flash after 20 seconds. All three buttons are now cleared. The HomeLink system is now in the setting mode.
2. Hold the original remote control of the device to be programmed at a distance of 10-30cm away from the HomeLink transmitter unit(at the rear-view mirror) keeping the LED in view all the time.
3. Using both hands, simultaneously push the remote control button and the desired HomeLink button (1, 2 or 3).
4. The LED will flash, first slowly and then rapidly. When the LED flashes rapidly, release both buttons. The rapid flashing light indicates successful programming of the new frequency signal.
RallyBird
10-07-2015 01:20 PM
I'mAllIn
08-25-2015 09:44 AM
