Windsheild washer fluid top up....
Old 10-09-2011 | 04:04 PM
chirag's Avatar
chirag is a jewel in the roughchirag is a jewel in the roughchirag is a jewel in the rough
Im getting the error that my windshield washer fluid is low; but when I try to put the fluid into the siphon, it doesnt go down the tube...anyone had a problem like this?
Old 10-10-2011 | 03:54 AM
Vergis's Avatar
Vergis has a spectacular aura aboutVergis has a spectacular aura aboutVergis has a spectacular aura about
Maybe your sensor is malfunctioning and the washer fluid is already topped up. Cant think how a block would occur in this part of the car system.
Old 10-10-2011 | 09:18 AM
Irish07@VelocityAP's Avatar
Very possible that it is blocked, the filler tube to the neck gets kinked by the PCM harness.. but this doesn't "just" happen to be blocked, notice this usually after a PDI or if work was done in that area recently. If your filler neck is full and your getting the msg on the dash, you could always remove the RHF inner fender molding to see the washer fluid bottle..if the bottle is full or above the level sensor..your chances of a faulty level sensor is high..there not hard to replace and not to costly for the part
Old 10-10-2011 | 07:20 PM
CJPatel's Avatar
CJPatel has a spectacular aura aboutCJPatel has a spectacular aura about
Mine drained slowly. dunno what the problem was, but I've only driven in the rain like 3 times, and neverrrr had to use the windsheild washer fluid, (apart from the drive home after I bought it).
Rguy
04-12-2020 11:11 PM
oo7
09-10-2015 08:08 AM
su_maverick
09-08-2015 11:12 AM
Wildcat1212
09-05-2015 05:35 PM
AdPock
Ferrari
09-01-2015 10:13 PM
Quick Reply: Windsheild washer fluid top up....
