Screw size for mounting rear plate
Does anyone know the proper diameter of the screws used to mount the rear plate (US spec)? I only have the top two in place. The stock screws are fairly long for the bottom portion of the mount and I don't want to scratch the CF under the bracket.
I had to replace the screws of my license plate on both cars I've owned and recall having to finagle something both times. Only problem is I can't remember exactly what my solution was. I do at least recall using relatively short screws, grinding down the sharp tips of the screws to avoid damaging the car, and applying a few spaced 1/2" thick pieces of foam weatherstripping (from Home Depot) to the back of the plate before putting it on the car to create some space between the plate and the car. With the foam, you don't need to screw down the screws as far (and risk threading into the car) and the plate won't vibrate or move around.
If you still need the screw size and length I used, I can take one of them out and measure. Just let me know.
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
ModBargains
Audi Vendor Classifieds
09-01-2015 05:26 PM
ModBargains
08-20-2015 12:28 PM
