DIY Air Oil Separator
I had PPI done on my car today and they found some oil on the engine and it looks like two bolts had worked their way loose on one the cover behind the pulleys. I think its is the AOS that is leaking, it does have oil on it. Is there a better way to be sure?
Alex
Alex
The cover behind the pulleys is the timing chain cover (the on associated with the notorious "timing cover gasket leak").
The AOS leaking is a separate issue. If it's leaking, you see it on the hose coming out of the bottom of it:
Actually they generally leak from the top near the tri seal area, the oil found at the bottom is the result of the oil leaking down.
04-28-2022 12:38 AM
away
09-04-2015 12:30 PM
hacellular
08-31-2015 08:34 AM
