Gear box fault code
Old 06-01-2012 | 05:37 PM
RHYNO's Avatar
RHYNO is infamous around these parts
I took my Vantage to the dealer 400km away for a regular service and to look at this issue. They could not find any codes stored in the computer so they installed the latest ASM software to the TCM. They also reflashed my ECM to the latest software level. I picked up my car and started my trip home and I had the fault come on three times. All three times the only thing that happened was the warning on the dash popped up for a second then went away, the car stayed in gear all three times. Also my clutch is still good. I guess I will have to live with this issue, the good thing is it just seems to be a glitch and nothing bad.
Old 06-01-2012 | 08:56 PM
Stuart Dickinson's Avatar
Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !
You go to MCL or Distinctive?
Old 06-02-2012 | 11:16 AM
RHYNO's Avatar
MCL is way closer so I took it there.
They REALLY liked the sound of my exhaust!!!! I ended up giving them your info.
Old 06-02-2012 | 11:18 AM
Jay_Davis's Avatar
Jay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud of
FYI: They couldn't tell anything was wrong with my clutch until they physically removed it and measured it.
Old 06-02-2012 | 03:56 PM
I will have to get in touch with them...
Do you ever take the Hope-Princeton or always the Coquihalla?
Old 06-02-2012 | 11:48 PM
RHYNO's Avatar
I always take the Coquilhalla. It's faster and 4 lanes the whole way so you don't get stuck behind any slow campers.
Old 06-04-2012 | 06:05 AM
Irish07@VelocityAP's Avatar
If your still getting no fault, but flashing the TCU changed things up a bit..honestly thinking you might have a corrupt TCU. Only real way of knowing this is to just swap out the TCU and drive it...if your local dealer can get it to ocur, get them to swap out the TCU with a spare unit and have them drive it to see if the fault returns..
When ever there is a Gear fault displayed in the dash, TCU records the fault and sends a msg to the DIM to display the msg..so your TCU is sending a msg to the DIM stating there is a fault..if there is no fault recorded then why would it be sending a msg..aka internal fault with TCU
This could even be a fault with the DIM displaying the msh for no reason, aka internal fault with DIM...but thats a long shot, I'd shoot for the TCU first and rule it out by swapping in a spare unit
Old 06-04-2012 | 10:15 AM
RHYNO's Avatar
Thanks for the info Irish07
Old 06-04-2012 | 10:18 AM
Definite advantage. I do love the Hope-Princeton though. If you get it on a weekday when there's not too much traffic it is sublime.
rzmnco
Cayenne 955/957
08-21-2024 09:57 AM
WheelB
991 Turbo Vendor Classifieds
07-23-2018 09:37 PM
DLF
Cayenne Turbo
10-24-2015 11:27 AM
AuZZie
09-02-2015 04:26 PM
Quick Reply: Gear box fault code
