Carbon Revolution – The world’s first one piece carbon fiber wheel for automotive.
Dear 6 Speed Members,
It is good to be back I am a former sponsor and member.
I wanted to introduce Carbon Revolution, the company that I have recently joined.
After years of research and development, Australian based Carbon Revolution has succeeded in solving one of the last remaining holy grails of the industry - A full one-piece carbon fiber wheel.
The entire wheel structure is molded as a single piece utilizing high end composite materials, currently built in sizes 19x8.5 (15.4lb) & 19x12 (17.9lb) and designed to mount directly on Porsche 911's. The wheels are compatible with factory tire pressure monitoring systems, accept factory center caps and come complete with all required installation hardware.
The wheels are 40% -50% lighter than premium OEM equivalents made from Aluminum. Carbon Revolution has used specialised wheel testing laboratories and testing tracks around the world to ensure that the most rigorous standards imposed by European OEMs have been tested for.
These products are high tech works of art, but then the performance advantages are the best value tuning to be bought for any vehicle. The manufacturing process is highly efficient and controllable. It has merged the rigor of aerospace processes with the efficiency and control of high volume automotive production.
Amongst the team are ex-OEM senior engineers from chassis development and drive train roles, senior manufacturing executives from world leading automotive component suppliers, R&D specialists from leading aircraft manufacturers, industrial composites manufacturing specialists and numerous PhD's with world leading materials and structures knowledge.
Carbon Revolution wheels will improve the performance of your car in many ways. Bolting on a set of lightweight CR-9 wheels is equivalent to:
· Adding horse power to the engine (increased acceleration)
· Increasing the size of the brakes (shorter stopping distances)
· Fitting stickier tires (improved grip)
· Upgrading your suspension (steering and handling improvements)
· Adding more sound insulation to the vehicle (Reduced road noise)
· Reduced vehicle mass (fuel savings)
Carbon Revolution wheels will be sold through select Specialty Tire & Wheel retailers, performance tuners and high end boutique car dealerships worldwide.
This is a remarkable and unique new technology and now there is the opportunity to experience it for yourselves.
I can be contacted directly on bill.koenig@carbonrev.com and you can read more about us at www.carbonrev.com
Seems like every F1 race I watch, CF pieces are shattering all over the track.
Looks ok....I guess. I didn't read the description so I don't know if the price was mentioned but its got to be pretty high up there. For big money, performance is a requirement.....but so is outstanding good looks.
Some prople don't care about looks. Some people value extreme exclusivity. The wheel should sell well to the people that can afford them.
The low weight but high stiffness of carbon fibre gives a very light weight wheel to the vehicle, significantly reducing the moment of inertia. This saves a considerable amount of power in turning the wheel. Consider that a standard Porsche 997 turbo 19” wheel weighs about 24 lbs.; the Carbon Revolution CR9 equivalent weighs around 14lbs saving about 40lbs per car.
The effect on the car however, is much more than the static weight saving. The moment of inertia calculation is based on the ratio of the mass multiplied by the square of the radius, meaning that as the diameter of the wheel increases then the greater the energy consumption of increased weight becomes.
The effect of Carbon Revolution mono block carbon wheels when fitted to the car is to reduce the gyroscope effect of the wheel this gives the following effects:
1. Improved acceleration
2. Improved braking, reduced stopping distance
3. Lighter, sharper steering, gives better feel and more responsive handling.
4. Allows for softer suspension damper settings giving more tire contact & therefore better grip.
5. Tire temperatures and pressures are more stable
6. Improved wheel & tire balancing
7. Fuel consumption reduces
