Ace 20" Convex w/ 007 Aston Martin Vantage
DrCollie:
Also as per their specification sheet: http://www.acealloywheel.com/downloa...Applicaton.pdf
The highest offset they offer for fronts is 40mm, and 45mm rear. You could do 38mm fronts (19x8.5"), and 45mm rear (19"x10") and it should be good enough. its alittle bit more aggressive, but its doable at 10". 10.5" would be too much at 45mm IMO. This would be the equivalent of 15mm spacers up front, and 20mm spacers rear on stock wheels roughly. Anything more would be too much.
In my opinion this is by far the best offset option. You can run more aggressive up front b/c the 19's still retain the 8.5" width and you do need to push out the front wheels quite a bit for the right look. Because you are increase rears by half an inch you go less aggressive on the offset in the rear (highest numerical offset, counter intuitive ).
On the V12s you would have to run 20" because you need to run 10.5" rear for grip (at least 305s in rear, you can even squeeze 315s on a 10.5 but its tight). So on the V12s again same concept, highest offset possible for 20x9 @ 40mm & 20x10.5 @ 35mm (although 35mm is still too low, you really need to be running a 45mm in rear with 10.5. Perhaps they can do a custom setup in this size for astons). In Fact, I bet you those 20s in the pic are 35mm rear offset, and you can see its still too wide. You need at least another 10mm more off offset to bring the wheel in more about 10mm as previously stated.
Hope that helps
Hope that helps
But is that MSRP or wholesale? I am rather fond of the Mesh 7 on their web site.
DrCollie:
Hope that helps
Hope that helps
So I ordered a staggered set of these tonight - from Element Wheels. $ 1,230 for the whole set, shipped. That's not bad. Going with your recommendations 007 V. on the 19's.
Wow what a steal!! You will not be disappointed, the concave look with spokes going to the edge and proper offset will make the wheels look bigger than the stock ones. 25 series tire is asking for trouble, you made the right choice!
ACE Convex w/ 007 Aston Martin
Specs:
Vehicle: Aston Martin Vantage
Wheel Specs: 20x9 Front / 20x10.5 Rear
Wheel : Ace Convex - HyperSilver
VIDEO:
Full Article On ESM 007 Aston Martin w/ Ace Convex - http://www.essentialstyleformen.com/...-stand-part-2/
also, did you mean to say Concave vs. Convex?
those wheels are not that Convex looking
This New Concave Style Wheel Offers The Best In Form And Function, Constructed With Elegant Style And Latest Technology. This Multi Spoke Gives And Aggressive Look With A Deep Concave Design. Available in 18", 19" (8.5/10) 20" ( 4 Different Widths From 8.5-10.5 Widths) , 22" (9/10.5) Staggered Set Ups. Available In Matte Black, HyperBlack w/ Machine Face & Gloss Black w/ Machine Face, Titanium, Matte Silver w/ Machine Face, Matte Black w/ Machine Face.
the wheels are slightly heavier than stock, but not by too much. However, you could greatly offset this by running a set of Michelin Pilot Super sports instead of RE050s, which are roughly 3-4lbs lighter per tire (at the furthest outer edge where it counts the most). Overall, the wheel & tire combo would still be lighter than stock. I would recommend if you run them, get the pilot super sports. The wheels are gorgeous, so they are worth it. I would recommend getting the 19s just to get better tire availability and ride quality IMO
That is actually a great setup for 19", but until we get more demand for them, we won't be bringing it in until then.
