Exhaust valves stuck, help?
Hi, I was out the other night with my v8v, everything was sounding just right. I parked for a while and when I started the car and drove off the sound of my exhaust was significantly louder. It is only loud when the engine.is under load accelerating. To me it sounds like my exhaust valves that are normally closed below 4000rpm? Are stuck in the open position. Everything else is working correctly, no CEL, smell, etc. I have RSC headers and cats, stock exhaust. Have had all of that for more than 9 months.
Thanks for the help.
Also, after further "listening" to the sound it is not the valve that is stuck open as I can still hear it come open after high RPM. Seems like the sound is coming directly from the muffler. It actually sounds pretty cool, but way too loud to be normal. I just ordered a new exhaust from Stu. I figured if I have to repair anything on the old exhaust might as well just get a new one and be done with it.
The vacuum lines that control the valve break. Either the rubber pieces to the valves themselves or the plastic 'T' , or on one car the plastic line breaks. This can cause the valves to stay open, just as if fuse 22 was pulled. The best way is to get under the car when it's cold, don't want to burn ourselves now, and check the connection at the two vacuum valves on the muffler itself. If there ok, near the passenger side rear where the pump is or near the passenger side valve the Vacuum T is there, check it too.
Any resolution to this? Post what you've found in case someone else encounters the same issue.
Will do, I will check tonight. It was dark when I arrived home last night too late to see anything under the car.
10-06-2015 03:43 PM
turbotuner20v
09-11-2015 12:02 PM
Ferrari
08-24-2015 04:35 PM
