What has your Aston been mechanically? Major issues?
#46
OP there is a small software update to ASM1 when the 4.7 came in but nothing that affects creep mode or the high reverse ratio
Best thing to do is keep doing regular clutch learns and avoid creep mode as often as possible
#47
Buying the "right" spec used in factory warranty then making sure it is sorted before the factory warranty runs out is a good idea. The extended warranty has a LOT of exclusions
#50
This is ridiculous, you should be able to drive a car without so many **** asterisks everywhere...
This is why I'm not going to be driving mine anymore every day, it's horrible as a commuter!
Coming from DCT and autos I couldn't conceive how this would be, but it is.
It's just a PITA to drive in traffic.
#53
2013 V8 Vantage 5400 miles..... third pedal :-)
Fuel tank fill gets stuck and need a string to get it open ...
Probably just needs an adjustment .... Other than that it has been flawless ....
I absolutely love the car... Could use 100 more hp ...
#54
that's why sportshift, paddleshift etc sell for loads less $$ on hte used market, across the board, ferrari, aston, maserati (the maserati paddleshifter is horrendous). I'd actually been looking at a maserati gt a couple years ago, but manuals are scarce and the paddleshifter incredibly fragile.
When searching for my vantage, I didn't even bother to look at listings of sportshift cars.
Chris
Chris
#55
I don't think so. Their automatic is better than the Vantage's SportShift. The biggest problem with it was that it had absolutely no luggage space. The total space you had was room for 1 briefcase. The coupe is better in that regards, but that just went on sale this month.
The other issue is that the V8 version is a little expensive. Once you break $100K people start looking at other things.
#56
Oh and Ive had my car for about 18 months and put about 11k on it so far (26k total). Not too painful:
-water leak into a rear led (had to be replaced) roughly 2k
-squeaky belt retrofit ($600)
-brake pads and rotors on the way out (will be calling Stu shortly about ordering the wilwoods)
#58
My 2005 DB9 has pretty much needed nothing but fluid changes. It has been a great "super car" in terms of reliability. I did have the gear that runs the navigation display motor fail. I later found out the grease AM used on these gears back in the day had a chemical reaction with the plastic gear causing it to disintegrate over time. Aston has since come out with a "update kit" that I had installed. The other issue is the transmission cooler lines started to leak on me which I had repaired as well. I have had the car 2 years and those were the only nagging issues. Pretty impressive.
#60
Bit of an update on mine
When BR did the failed ASM2 gearbox rebuild they also found a failing rear wheel bearing on an 18 month old 13k mile car
They replace both sides
I wonder if that was related to the gearbox issues?
