SRS airbag light is on after seat removal
Old 07-02-2014 | 01:19 PM
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
I decided to do a major cleaning on my DB9 and removed the passenger seat (battery disconnected) to vacuum under it. While vacuuming, it started to rain, so in a panic I reconnected the battery and put the car back in the garage. Unfortunately, the passenger seat was out when I did this and I believe it triggered the airbag light. I'm pretty sure cars from the mid 2000's had a pressure switch in the seat for the airbag and when it wasn't connected the car freaked out. I have left the battery disconnected for almost 3 weeks with no luck in getting this light to come off. Does anyone know of a tool that can reset the airbag light on a DB9 or I'm I looking at a dealer visit? Thanks in advance.
Old 07-02-2014 | 01:39 PM
XJRS Owner's Avatar
Autel EU702 works.
Old 07-02-2014 | 02:55 PM
dan87951's Avatar
Thanks just ordered one.
Old 07-19-2014 | 09:52 AM
dan87951's Avatar
Do you connect it to the OBDII or Body port? When connected to the OBD II port it cannot communicate with the srs system no matter what year XC90 i choose. Just my luck...
Old 07-19-2014 | 10:54 AM
karlfranz's Avatar
^^^ Didn't you just answer your own question?
Old 07-19-2014 | 12:42 PM
dan87951's Avatar
No... I didn't not connect it to the body port in fear of something bad could happen. Didn't know if the "body port" follows the same OBDII com. protocols so didn't chance it. I take it by your response it must be connected to the body port than?
Old 07-19-2014 | 02:11 PM
karlfranz's Avatar
Yes, the body port is where you want to plug in. The Autel is designed to work with either port, so no worries, you'll be fine.
Old 07-19-2014 | 04:55 PM
dan87951's Avatar
Thanks it worked.
Old 07-19-2014 | 09:53 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
I recommend the 802 if you are willing to spend a little more cash as it has way more functionality
Old 03-21-2016 | 06:33 AM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
Can anyone tell me more about 802 full system ? Is it Ortho extra 100-125 dollars?
What more functions can be used for Aston Martin 2009 db9 or Lamborghini gallardo 2011 lp 560-4
Old 03-21-2016 | 06:43 AM
tomluice's Avatar
tomluice is infamous around these parts
I had a similar experience last year
Old 02-01-2019 | 08:00 PM
wwtxamdb9's Avatar
Registered PM
wwtxamdb9 is infamous around these parts
I realize this is an old thread, but I would like to thank those who contributed to it. I removed my drivers seat to work on it's upholstery and didn't think about the air bag issue. When I reinstalled the seat, it showed the warning. I ordered the Aultel 802, used the Volvo XC90 input, and had the warning cleared in a couple of minutes. The info on this forum saves a lot of frustration.
pwdrhound
08-23-2015 07:36 PM
riozilla
08-21-2015 11:34 PM
pwdrhound
08-20-2015 05:54 AM
Walorus
08-18-2015 01:39 PM
Quick Reply: SRS airbag light is on after seat removal
