Look at these dirty cabin air filters only at 20K
Old 08-10-2014 | 05:13 PM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
I just replaced my cabin air filter/pollen filters.
My car has 20k miles now, bought at 16.5 K, not sure when it was replaced before.
See the pictures, new ones are white unless old ones were some kind of charcoal activated (my BMW has those)
Replacing filters are very easy, took me 10-15 min at most, similar to my Acura MDX previously I had owned (actually mdx was more difficult)
Old 08-12-2014 | 07:52 AM
rscultho's Avatar
rscultho is infamous around these parts
Where are they located?
Old 08-12-2014 | 08:49 AM
jcpca356's Avatar
jcpca356 is a splendid one to beholdjcpca356 is a splendid one to beholdjcpca356 is a splendid one to beholdjcpca356 is a splendid one to beholdjcpca356 is a splendid one to beholdjcpca356 is a splendid one to behold
ooo better go look at mine. thx
Old 08-12-2014 | 10:49 AM
they are behind the glove box on passenger side
lie down on your back in the car on passenger seat, look under the glove box. (stick your head under the glove box)
remove 3 screws--glove box will come out
now remove 4 more screws from black panel which is visible after removing glove box.
you may have to just pull and remove leather wrapped trim piece around the glove box which has switch for opening the glove box.
now you should see a rectangular white panel with two clips on side just remove that and there is your pollen filter, swap them put things back together and done.
probably saved a bunch, I ordered filters from HWS with whole bunch of other parts.
Old 08-12-2014 | 04:41 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Great time to do this is when you are replacing the leather trim dash pieces as you have to get to this anyways. Will be swapping out my old ones with carbon filters once my new dash pieces come in.
What year is your car wildcat? Just curious if age also plays a factor
Old 08-12-2014 | 04:49 PM
It's 2009
I don't think age will matter but mileage because that's what would expose to dirt.
Old 08-12-2014 | 06:28 PM
911MTB's Avatar
911MTB is infamous around these parts
[QUOTE=007 Vantage;4173805]Great time to do this is when you are replacing the leather trim dash pieces as you have to get to this anyways. Will be swapping out my old ones with carbon filters once my new dash pieces come in.
Just curious where you ordered your replacement dash pieces from?
Old 08-12-2014 | 06:37 PM
zvez's Avatar
zvez is just really nicezvez is just really nicezvez is just really nicezvez is just really nice
Aston martin OEM replacement leather parts are surprisingly reasonable. You can order from astonmartincarparts.com in the UK. Or from your dealer
[QUOTE=911MTB;4173866]
Old 08-13-2014 | 07:39 AM
Aston Martin HWM. They are surprisingly very reasonable and the factory makes them to your exact VIN. Both instrument cluster binnacle and passenger dash trim piece costs less than $500 shipped!m at those prices I have no idea why anybody goes to a thirs party upholsterer to reglue their old ones when they can get brand new ones with the updated stronger adhesive. All the upholstery shops were quoting me $800-1000min. Seems like a no brainer
Ordered the charcoal filters off ebay for super cheap, will be putting them in once the dash pieces arrive.
Old 08-13-2014 | 07:56 AM
911MTB's Avatar
[QUOTE=007 Vantage;4174110]
Thanks for the feedback, I'll try online. My local AM dealer quoted me $1400 plus tax for the passenger airbag cover piece and passenger trim piece. Seems pretty high to me for those two pieces.
Old 08-13-2014 | 08:25 AM
zvez's Avatar
passenger airbag cover is $485 from astonmartincarparts.com in UK
http://www.astonmartincarparts.com/p...63-190754.html
[QUOTE=911MTB;4174127]
Old 08-13-2014 | 10:12 AM
what charcoal filters are you talking about?
can you post a link?
I hope it will fit DB9 too
Old 08-13-2014 | 10:49 AM
zvez's Avatar
these
http://www.amazon.com/s/ref=nb_sb_no...iglink20664-20
see this thread
https://www.6speedonline.com/forums/...n-vantage.html
[QUOTE=Wildcat1212;4174213]
Old 09-22-2015 | 03:30 PM
KOCF's Avatar
KOCF is a jewel in the roughKOCF is a jewel in the roughKOCF is a jewel in the roughKOCF is a jewel in the rough
Cabin air filter part numbers
Found this thread and decided I needed to change my cabin air filters. Thanks to Wildcat for excellent instructions on how they are accessed. Got them out in just a few minutes. Tried to get the ATP RA-16 filters mentioned in this thread as available from Amazon locally, but found they were not in stock anywhere.
A diligent counterman at O'Reilly auto parts found a cross reference from the ATP number to a Microgard plain filter #3669 which lists for $16.99 and an equivalent Charcoal filter which is a WIX #24826 at $20.99. I used the Microgard which was an exact duplicate to what I removed. Any O'Reilly store should have these in stock or can get them quickly.
A word of caution - When removing the glove box, note that there is an elastic lanyard attached to a plastic clip on the outboard side of the box. I imagine this provides the spring to close the glove box. In case the lanyard slips off the clip, before removing the black plastic piece behind the glove box, note through which hole the lanyard is routed so you can assemble things properly.
danyoP4S
09-30-2021 06:06 AM
Rockinc1
09-30-2015 07:44 PM
shifter_
09-08-2015 01:07 PM
holmesatx
09-02-2015 12:32 PM
